Retrieve remote syslog or splunk server information
GET /security/audit/destinations/{address}/{port}
Introduced In: 9.6
Defines a remote syslog/splunk server for sending audit information to.
address  |
string  |
path  |
True  |
IP address of remote syslog/splunk server.  |
port  |
integer  |
path  |
True  |
Port number of remote syslog/splunk server.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
address  |
string  |
Destination syslog|splunk host to forward audit records to. This can be an IP address (IPv4|IPv6) or a hostname.  |
facility  |
string  |
This is the standard Syslog Facility value that is used when sending audit records to a remote server.  |
port  |
integer  |
Destination Port. The default port depends on the protocol chosen: For un-encrypted destinations the default port is 514. For encrypted destinations the default port is 6514.  |
protocol  |
string  |
Log forwarding protocol  |
verify_server  |
boolean  |
This is only applicable when the protocol is tcp_encrypted. This controls whether the remote server's certificate is validated. Setting "verify_server" to "true" will enforce validation of remote server's certificate. Setting "verify_server" to "false" will not enforce validation of remote server's certificate.  |
  "address": "string",
  "facility": "string",
  "protocol": "string"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
