Retrieve the administrative audit log viewer
GET /security/audit/messages
Introduced In: 9.6
Retrieves the administrative audit log viewer.
command_id  |
string  |
query  |
False  |
Filter by command_id  |
application  |
string  |
query  |
False  |
Filter by application  |
svm.name  |
string  |
query  |
False  |
Filter by svm.name  |
input  |
string  |
query  |
False  |
Filter by input  |
node.name  |
string  |
query  |
False  |
Filter by node.name  |
node.uuid  |
string  |
query  |
False  |
Filter by node.uuid  |
index  |
integer  |
query  |
False  |
Filter by index  |
user  |
string  |
query  |
False  |
Filter by user  |
session_id  |
string  |
query  |
False  |
Filter by session_id  |
state  |
string  |
query  |
False  |
Filter by state  |
message  |
string  |
query  |
False  |
Filter by message  |
scope  |
string  |
query  |
False  |
Filter by scope  |
location  |
string  |
query  |
False  |
Filter by location  |
timestamp  |
string  |
query  |
False  |
Filter by timestamp  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_timeout  |
integer  |
query  |
False  |
return_records  |
boolean  |
query  |
False  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of records  |
records  |
array[security_audit_log]  |
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "application": "string",
      "command_id": "string",
      "index": 0,
      "input": "string",
      "location": "string",
      "message": "string",
      "node": {
        "name": "node1",
      "scope": "string",
      "session_id": "string",
      "state": "string",
      "svm": {
        "name": "string"
      "timestamp": "string",
      "user": "string"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
_links
self  |
node
Node where the audit message resides.
_links  |
name  |
string  |
uuid  |
string  |
svm
This is the SVM through which the user connected.
name  |
string  |
security_audit_log
_links  |
application  |
string  |
This identifies the "application" by which the request was processed.  |
command_id  |
string  |
This is the command ID for this request. Each command received on a CLI session is assigned a command ID. This enables you to correlate a request and response.  |
index  |
integer  |
Internal index for accessing records with same time/node. This is a 64 bit unsigned value.  |
input  |
string  |
The request.  |
location  |
string  |
This identifies the location of the remote user. This is an IP address or "console".  |
message  |
string  |
This is an optional field that might contain "error" or "additional information" about the status of a command.  |
node  |
Node where the audit message resides.  |
scope  |
string  |
Set to "svm" when the request is on a data SVM; otherwise set to "cluster".  |
session_id  |
string  |
This is the session ID on which the request is received. Each SSH session is assigned a session ID. Each http/ontapi/snmp request is assigned a unique session ID.  |
state  |
string  |
State of of this request.  |
svm  |
This is the SVM through which the user connected.  |
timestamp  |
string  |
Log entry timestamp. Valid in URL  |
user  |
string  |
Username of the remote user.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
