Retrieve IPsec policies
GET /security/ipsec/policies
Introduced In: 9.8
Retrieves the collection of IPsec policies.
Related ONTAP commands
security ipsec policy show
uuid |
string |
query |
False |
Filter by uuid |
name |
string |
query |
False |
Filter by name |
protocol |
string |
query |
False |
Filter by protocol |
scope |
string |
query |
False |
Filter by scope |
remote_endpoint.netmask |
string |
query |
False |
Filter by remote_endpoint.netmask |
remote_endpoint.family |
string |
query |
False |
Filter by remote_endpoint.family |
remote_endpoint.address |
string |
query |
False |
Filter by remote_endpoint.address |
enabled |
boolean |
query |
False |
Filter by enabled |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
local_endpoint.netmask |
string |
query |
False |
Filter by local_endpoint.netmask |
local_endpoint.family |
string |
query |
False |
Filter by local_endpoint.family |
local_endpoint.address |
string |
query |
False |
Filter by local_endpoint.address |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
error |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"num_records": "1",
"records": [
"local_endpoint": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24"
"name": "string",
"protocol": "17",
"remote_endpoint": {
"family": "string",
"netmask": "24"
"scope": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
local_endpoint
Local endpoint for the IPsec policy.
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length. |
remote_endpoint
Remote endpoint for the IPsec policy.
address |
string |
family |
string |
IPv4 or IPv6 |
netmask |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
records
IPsec policy object.
enabled |
boolean |
Indicates whether or not the policy is enabled. |
local_endpoint |
Local endpoint for the IPsec policy. |
name |
string |
IPsec policy name. |
protocol |
string |
Lower layer protocol to be covered by the IPsec policy. |
remote_endpoint |
Remote endpoint for the IPsec policy. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
uuid |
string |
Unique identifier of the IPsec policy. |
