REST API reference
Retrieve an IPsec configuration
GET /security/ipsec
Introduced In: 9.8
Retrieves IPsec configuration via REST APIs.
  • 'security ipsec config show'
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 1
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
fields
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
self_link
enabled
boolean
Indicates whether or not IPsec is enabled.
      "href": "/api/resourcelink"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
