Retrieve key servers configured in an external key manager
GET /security/key-managers/{uuid}/key-servers/{server}
Introduced In: 9.6
Retrieves key servers configured in an external key manager.
Related ONTAP commands
security key-manager external show -
security key-manager external show-status
uuid |
string |
path |
True |
External key manager UUID |
server |
string |
path |
True |
Key server configured in the key manager. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
password |
string |
Password credentials for connecting with the key server. This is not audited. |
secondary_key_servers |
array[string] |
A list of the secondary key servers associated with the primary key server. |
server |
string |
External key server for key management. If no port is provided, a default port of 5696 is used. Not valid in POST if |
timeout |
integer |
I/O timeout in seconds for communicating with the key server. |
username |
string |
KMIP username credentials for connecting with the key server. |
"href": "/api/resourcelink"
"password": "password",
"secondary_key_servers": [
"string"
"server": "keyserver1.com:5698",
"timeout": "60",
"username": "username"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
records
_links |
password |
string |
array[string] |
server |
string |
timeout |
integer |
username |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
