List key servers configured in an external key manager
GET /security/key-managers/{uuid}/key-servers
Introduced In: 9.6
Retrieves the list of key servers configured in an external key manager.
uuid |
string |
path |
True |
External key manager UUID |
timeout |
integer |
query |
False |
Filter by timeout |
secondary_key_servers |
string |
query |
False |
Filter by secondary_key_servers
server |
string |
query |
False |
Filter by server |
username |
string |
query |
False |
Filter by username |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[key_server] |
"next": {
"href": "/api/resourcelink"
"records": [
"password": "password",
"secondary_key_servers": [
"string"
"server": "keyserver1.com:5698",
"timeout": "60",
"username": "username"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
records
_links |
password |
string |
Password credentials for connecting with the key server. This is not audited. |
array[string] |
A list of the secondary key servers associated with the primary key server. |
server |
string |
External key server for key management. If no port is provided, a default port of 5696 is used. Not valid in POST if |
timeout |
integer |
I/O timeout in seconds for communicating with the key server. |
username |
string |
KMIP username credentials for connecting with the key server. |
key_server
_links |
password |
string |
array[string] |
server |
string |
timeout |
integer |
username |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
