Retrieve a specific SnapMirror policy
GET /snapmirror/policies/{uuid}
Introduced In: 9.6
Retrieves a specific SnapMirror policy.
Example
GET "/api/snapmirror/policies/567aaac0-f863-11e8-a666-0050568e12c2"
Learn more
uuid |
string |
path |
True |
Policy UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
comment |
string |
Comment associated with the policy. |
identity_preservation |
string |
Specifies which configuration of the source SVM is replicated to the destination SVM. This property is applicable only for SVM data protection with "async" policy type. |
name |
string |
network_compression_enabled |
boolean |
Specifies whether network compression is enabled for transfers. This is applicable only to the policies of type "async". |
retention |
array[snapmirror_policy_rule] |
Policy on Snapshot copy retention. |
scope |
string |
Set to "svm" for policies owned by an SVM, otherwise set to "cluster". |
svm |
sync_common_snapshot_schedule |
Schedule used to create common Snapshot copies for synchronous relationships. |
sync_type |
string |
throttle |
integer |
Throttle in KB/s. Default to unlimited. |
transfer_schedule |
The schedule used to update asynchronous relationships. |
type |
string |
uuid |
string |
"href": "/api/resourcelink"
"comment": "string",
"identity_preservation": "string",
"name": "Asynchronous",
"retention": [
"count": "7",
"creation_schedule": {
"name": "weekly",
"label": "hourly",
"prefix": "string"
"scope": "string",
"svm": {
"name": "svm1",
"sync_common_snapshot_schedule": {
"name": "weekly",
"sync_type": "string",
"throttle": 0,
"transfer_schedule": {
"name": "weekly",
"type": "string",
Status: Default
ONTAP Error Response codes
| Error code | Description |
13303842 |
SnapMirror policy is not supported. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
creation_schedule
Schedule used to create Snapshot copies on the destination for long term retention.
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
SnapMirror policy rule for retention.
count |
integer |
Number of Snapshot copies to be kept for retention. |
creation_schedule |
Schedule used to create Snapshot copies on the destination for long term retention. |
label |
string |
Snapshot copy label |
prefix |
string |
Specifies the prefix for the Snapshot copy name to be created as per the schedule. If no value is specified, then the label is used as the prefix. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
transfer_schedule
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
