REST API reference
Retrieve SnapMirror async and sync policy types
GET /snapmirror/policies
Introduced In: 9.6
Retrieves SnapMirror policies of type "async" and "sync".
  • snapmirror policy show
Example
The following example shows how to retrieve a collection of SnapMirror policies.
GET "/api/snapmirror/policies"
sync_common_snapshot_schedule.name
string
query
False
Filter by sync_common_snapshot_schedule.name
sync_common_snapshot_schedule.uuid
string
query
False
Filter by sync_common_snapshot_schedule.uuid
type
string
query
False
Filter by type
retention.creation_schedule.name
string
query
False
Filter by retention.creation_schedule.name
retention.creation_schedule.uuid
string
query
False
Filter by retention.creation_schedule.uuid
retention.prefix
string
query
False
Filter by retention.prefix
retention.count
integer
query
False
Filter by retention.count
retention.label
string
query
False
Filter by retention.label
transfer_schedule.name
string
query
False
Filter by transfer_schedule.name
transfer_schedule.uuid
string
query
False
Filter by transfer_schedule.uuid
comment
string
query
False
Filter by comment
name
string
query
False
Filter by name
identity_preservation
string
query
False
Filter by identity_preservation
scope
string
query
False
Filter by scope
uuid
string
query
False
Filter by uuid
sync_type
string
query
False
Filter by sync_type
throttle
integer
query
False
Filter by throttle
network_compression_enabled
boolean
query
False
Filter by network_compression_enabled
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[snapmirror_policy]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "comment": "string",
      "identity_preservation": "string",
      "name": "Asynchronous",
      "retention": [
          "count": "7",
          "creation_schedule": {
            "name": "weekly",
          "label": "hourly",
          "prefix": "string"
      "scope": "string",
      "svm": {
        "name": "svm1",
      "sync_common_snapshot_schedule": {
        "name": "weekly",
      "sync_type": "string",
      "throttle": 0,
      "transfer_schedule": {
        "name": "weekly",
      "type": "string",
Status: Default
ONTAP Error Response codes
Error code Description
13303842
SnapMirror policy is not supported.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
creation_schedule
Schedule used to create Snapshot copies on the destination for long term retention.
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
snapmirror_policy_rule
SnapMirror policy rule for retention.
count
integer
Number of Snapshot copies to be kept for retention.
creation_schedule
creation_schedule
label
string
Snapshot copy label
prefix
string
Specifies the prefix for the Snapshot copy name to be created as per the schedule. If no value is specified, then the label is used as the prefix.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
Schedule used to create common Snapshot copies for synchronous relationships.
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
transfer_schedule
The schedule used to update asynchronous relationships.
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
snapmirror_policy
SnapMirror policy information. SnapMirror policy can either be of type "async" or "sync". The policy type "async" can be associated with a SnapMirror relationship that has either the FlexVol volume or FlexGroup volume or SVM as the endpoint. The policy type "sync" along with "sync_type" as "sync" or "strict_sync" can be associated with a SnapMirror relationship that has FlexVol volume as the endpoint. The policy type "sync" can have a "sync_type" of either "sync", "strict_sync" or "automated_failover". If the "sync_type" is "sync" then a write success is returned to the client after writing the data to the source endpoint and before writing the data to the destination endpoint. If the "sync_type" is "strict_sync" then a write success is returned to the client after writing the data to the both source and destination endpoints. If the "sync_type" is "automated_failover" then the policy can be associated with a SnapMirror relationship that has Consistency Group as the endpoint. Use the "sync" policy with "sync_type" as "automated_failover" to establish SnapMirror relationships for business continuity usecases. SnapMirror relationships with policy type as "sync" and "sync_type" as "automated_failover" can be monitored by the Mediator, if configured. In case the source Consistency Group endpoint is not reachable, the Mediator may trigger a failover to the destination Consistency Group endpoint.
_links
_links
comment
string
Comment associated with the policy.
string
Specifies which configuration of the source SVM is replicated to the destination SVM. This property is applicable only for SVM data protection with "async" policy type.
name
string
boolean
Specifies whether network compression is enabled for transfers. This is applicable only to the policies of type "async".
retention
array[snapmirror_policy_rule]
Policy on Snapshot copy retention.
scope
string
Set to "svm" for policies owned by an SVM, otherwise set to "cluster".
svm
svm
sync_type
string
throttle
integer
Throttle in KB/s. Default to unlimited.
transfer_schedule
transfer_schedule
type
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
