Retrieve a collection of cloud stores used by an aggregate
GET /storage/aggregates/{aggregate.uuid}/cloud-stores
Introduced In: 9.6
Retrieves the collection of cloud stores used by an aggregate.
Related ONTAP commands
storage aggregate object-store show
aggregate.uuid |
string |
path |
True |
Aggregate UUID |
target.name |
string |
query |
False |
Filter by target.name |
target.uuid |
string |
query |
False |
Filter by target.uuid |
unavailable_reason.message |
string |
query |
False |
Filter by unavailable_reason.message
used |
integer |
query |
False |
Filter by used |
unreclaimed_space_threshold |
integer |
query |
False |
Filter by unreclaimed_space_threshold |
mirror_degraded |
boolean |
query |
False |
Filter by mirror_degraded |
availability |
string |
query |
False |
Filter by availability |
primary |
boolean |
query |
False |
Filter by primary |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[cloud_store] |
"next": {
"href": "/api/resourcelink"
"records": [
"availability": "string",
"target": {
"name": "target1",
"unavailable_reason": {
"message": "string"
"unreclaimed_space_threshold": "20",
"used": 0
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
target
Cloud target
_links |
name |
string |
uuid |
string |
message |
string |
Indicates why the object store is unavailable. |
cloud_store
_links |
availability |
string |
Availability of the object store. |
mirror_degraded |
boolean |
This field identifies if the mirror cloud store is in sync with the primary cloud store of a FabricPool. |
primary |
boolean |
This field indicates whether the cloud store is the primary cloud store of a mirrored FabricPool. |
target |
Cloud target |
unavailable_reason |
integer |
Usage threshold for reclaiming unused space in the cloud store. Valid values are 0 to 99. The default value depends on the provider type. This can be specified in PATCH but not POST. |
used |
integer |
The amount of object space used. Calculated every 5 minutes and cached. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
