Retrieve a collection of plexes for an aggregate
GET /storage/aggregates/{aggregate.uuid}/plexes
Introduced In: 9.6
Retrieves the collection of plexes for the specified aggregate.
Related ONTAP commands
storage aggregate plex show
aggregate.uuid |
string |
path |
True |
Aggregate UUID |
online |
boolean |
query |
False |
Filter by online |
name |
string |
query |
False |
Filter by name |
pool |
string |
query |
False |
Filter by pool |
resync.level |
string |
query |
False |
Filter by resync.level |
resync.active |
boolean |
query |
False |
Filter by resync.active |
resync.percent |
integer |
query |
False |
Filter by resync.percent |
aggregate.uuid |
string |
query |
False |
Filter by aggregate.uuid |
aggregate.name |
string |
query |
False |
Filter by aggregate.name |
raid_groups.reconstruct.percent |
integer |
query |
False |
Filter by raid_groups.reconstruct.percent
raid_groups.reconstruct.active |
boolean |
query |
False |
Filter by raid_groups.reconstruct.active
raid_groups.recomputing_parity.active |
boolean |
query |
False |
Filter by raid_groups.recomputing_parity.active
raid_groups.recomputing_parity.percent |
integer |
query |
False |
Filter by raid_groups.recomputing_parity.percent
raid_groups.degraded |
boolean |
query |
False |
Filter by raid_groups.degraded
raid_groups.name |
string |
query |
False |
Filter by raid_groups.name
raid_groups.disks.usable_size |
integer |
query |
False |
Filter by raid_groups.disks.usable_size
raid_groups.disks.disk.name |
string |
query |
False |
Filter by raid_groups.disks.disk.name
raid_groups.disks.state |
string |
query |
False |
Filter by raid_groups.disks.state
raid_groups.disks.type |
string |
query |
False |
Filter by raid_groups.disks.type
raid_groups.disks.position |
string |
query |
False |
Filter by raid_groups.disks.position
raid_groups.cache_tier |
boolean |
query |
False |
Filter by raid_groups.cache_tier
state |
string |
query |
False |
Filter by state |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
error |
num_records |
integer |
Number of records |
records |
array[plex] |
"next": {
"href": "/api/resourcelink"
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"records": [
"aggregate": {
"name": "aggr1",
"name": "plex0",
"pool": "string",
"raid_groups": [
"disks": [
"disk": {
"name": "1.0.1"
"position": "string",
"state": "string",
"type": "ssd",
"usable_size": "947912704"
"name": "rg0",
"recomputing_parity": {
"percent": "10"
"reconstruct": {
"percent": "10"
"resync": {
"level": "string",
"percent": "10"
"state": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
_links
self |
aggregate
Aggregate
_links |
name |
string |
uuid |
string |
disk
Disk
_links |
name |
string |
raid_group_disk
disk |
Disk |
position |
string |
The position of the disk within the RAID group. |
state |
string |
The state of the disk within the RAID group. |
type |
string |
Disk interface type |
usable_size |
integer |
Size in bytes that is usable by the aggregate. |
recomputing_parity
active |
boolean |
RAID group is recomputing parity |
percent |
integer |
Recomputing parity percentage |
reconstruct
active |
boolean |
One or more disks in this RAID group are being reconstructed. |
percent |
integer |
Reconstruct percentage |
raid_group
cache_tier |
boolean |
RAID group is a cache tier |
degraded |
boolean |
RAID group is degraded. A RAID group is degraded when at least one disk from that group has failed or is offline. |
disks |
array[raid_group_disk] |
name |
string |
RAID group name |
recomputing_parity |
reconstruct |
resync
active |
boolean |
Plex is being resynchronized to its mirrored plex |
level |
string |
Plex resyncing level |
percent |
integer |
Plex resyncing percentage |
plex
aggregate |
Aggregate |
name |
string |
Plex name |
online |
boolean |
Plex is online |
pool |
string |
SyncMirror pool assignment |
raid_groups |
array[raid_group] |
resync |
state |
string |
Plex state |
