REST API reference
Retrieve a collection of aggregates for an entire cluster
GET /storage/aggregates
Introduced In: 9.6
Retrieves the collection of aggregates for the entire cluster.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • metric.*
  • space.block_storage.inactive_user_data
  • space.footprint
  • statistics.*
  • storage aggregate show
recommend
boolean
query
False
If set to 'true', it queries the system for the recommended optimal layout for creating new aggregates. The default setting is 'false'.
show_spares
boolean
query
False
If set to 'true', the spares object is returned instead of records to show the spare groups in the cluster. The default setting is 'false'.
metric.timestamp
string
query
False
Filter by metric.timestamp
  • Introduced in: 9.7
metric.duration
string
query
False
Filter by metric.duration
metric.throughput.total
integer
query
False
Filter by metric.throughput.total
metric.throughput.read
integer
query
False
Filter by metric.throughput.read
metric.throughput.other
integer
query
False
Filter by metric.throughput.other
metric.throughput.write
integer
query
False
Filter by metric.throughput.write
metric.latency.total
integer
query
False
Filter by metric.latency.total
metric.latency.read
integer
query
False
Filter by metric.latency.read
metric.latency.other
integer
query
False
Filter by metric.latency.other
metric.latency.write
integer
query
False
Filter by metric.latency.write
metric.status
string
query
False
Filter by metric.status
metric.iops.total
integer
query
False
Filter by metric.iops.total
metric.iops.read
integer
query
False
Filter by metric.iops.read
metric.iops.other
integer
query
False
Filter by metric.iops.other
metric.iops.write
integer
query
False
Filter by metric.iops.write
uuid
string
query
False
Filter by uuid
name
string
query
False
Filter by name
space.efficiency_without_snapshots.logical_used
integer
query
False
Filter by space.efficiency_without_snapshots.logical_used
space.efficiency_without_snapshots.savings
integer
query
False
Filter by space.efficiency_without_snapshots.savings
space.efficiency_without_snapshots.ratio
number
query
False
Filter by space.efficiency_without_snapshots.ratio
space.footprint
integer
query
False
Filter by space.footprint
integer
query
False
Filter by space.block_storage.inactive_user_data
space.block_storage.size
integer
query
False
Filter by space.block_storage.size
space.block_storage.full_threshold_percent
integer
query
False
Filter by space.block_storage.full_threshold_percent
space.block_storage.available
integer
query
False
Filter by space.block_storage.available
space.block_storage.used
integer
query
False
Filter by space.block_storage.used
space.efficiency.logical_used
integer
query
False
Filter by space.efficiency.logical_used
space.efficiency.savings
integer
query
False
Filter by space.efficiency.savings
space.efficiency.ratio
number
query
False
Filter by space.efficiency.ratio
space.cloud_storage.used
integer
query
False
Filter by space.cloud_storage.used
snaplock_type
string
query
False
Filter by snaplock_type
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
block_storage.mirror.state
string
query
False
Filter by block_storage.mirror.state
block_storage.mirror.enabled
boolean
query
False
Filter by block_storage.mirror.enabled
block_storage.hybrid_cache.raid_type
string
query
False
Filter by block_storage.hybrid_cache.raid_type
block_storage.hybrid_cache.used
integer
query
False
Filter by block_storage.hybrid_cache.used
block_storage.hybrid_cache.disk_count
integer
query
False
Filter by block_storage.hybrid_cache.disk_count
block_storage.hybrid_cache.enabled
boolean
query
False
Filter by block_storage.hybrid_cache.enabled
block_storage.hybrid_cache.size
integer
query
False
Filter by block_storage.hybrid_cache.size
block_storage.plexes.name
string
query
False
Filter by block_storage.plexes.name
block_storage.primary.checksum_style
string
query
False
Filter by block_storage.primary.checksum_style
block_storage.primary.raid_size
integer
query
False
Filter by block_storage.primary.raid_size
block_storage.primary.disk_type
string
query
False
Filter by block_storage.primary.disk_type
block_storage.primary.disk_class
string
query
False
Filter by block_storage.primary.disk_class
block_storage.primary.disk_count
integer
query
False
Filter by block_storage.primary.disk_count
block_storage.primary.raid_type
string
query
False
Filter by block_storage.primary.raid_type
home_node.name
string
query
False
Filter by home_node.name
home_node.uuid
string
query
False
Filter by home_node.uuid
dr_home_node.uuid
string
query
False
Filter by dr_home_node.uuid
dr_home_node.name
string
query
False
Filter by dr_home_node.name
data_encryption.software_encryption_enabled
boolean
query
False
Filter by data_encryption.software_encryption_enabled
data_encryption.drive_protection_enabled
boolean
query
False
Filter by data_encryption.drive_protection_enabled
inactive_data_reporting.start_time
string
query
False
Filter by inactive_data_reporting.start_time
  • Introduced in: 9.8
inactive_data_reporting.enabled
boolean
query
False
Filter by inactive_data_reporting.enabled
create_time
string
query
False
Filter by create_time
statistics.iops_raw.total
integer
query
False
Filter by statistics.iops_raw.total
statistics.iops_raw.read
integer
query
False
Filter by statistics.iops_raw.read
statistics.iops_raw.other
integer
query
False
Filter by statistics.iops_raw.other
statistics.iops_raw.write
integer
query
False
Filter by statistics.iops_raw.write
statistics.latency_raw.total
integer
query
False
Filter by statistics.latency_raw.total
statistics.latency_raw.read
integer
query
False
Filter by statistics.latency_raw.read
statistics.latency_raw.other
integer
query
False
Filter by statistics.latency_raw.other
statistics.latency_raw.write
integer
query
False
Filter by statistics.latency_raw.write
statistics.timestamp
string
query
False
Filter by statistics.timestamp
statistics.status
string
query
False
Filter by statistics.status
statistics.throughput_raw.total
integer
query
False
Filter by statistics.throughput_raw.total
statistics.throughput_raw.read
integer
query
False
Filter by statistics.throughput_raw.read
statistics.throughput_raw.other
integer
query
False
Filter by statistics.throughput_raw.other
statistics.throughput_raw.write
integer
query
False
Filter by statistics.throughput_raw.write
state
string
query
False
Filter by state
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
error
error
num_records
integer
Number of records
records
array[aggregate]
spares
array[aggregate_spare]
    "next": {
      "href": "/api/resourcelink"
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
  "records": [
      "block_storage": {
        "hybrid_cache": {
          "disk_count": "6",
          "raid_type": "string",
          "size": "1612709888",
          "used": "26501122"
        "mirror": {
          "enabled": "",
          "state": "string"
        "plexes": [
            "name": "plex0"
        "primary": {
          "checksum_style": "string",
          "disk_class": "performance",
          "disk_count": "8",
          "disk_type": "string",
          "raid_size": "16",
      "cloud_storage": {
        "stores": [
            "cloud_store": {
              "name": "store1",
            "used": 0
      "create_time": "2018-01-01T12:00:00-04:00",
      "dr_home_node": {
        "name": "node1",
      "home_node": {
        "name": "node1",
      "inactive_data_reporting": {
        "start_time": "2019-12-12T12:00:00-04:00"
      "metric": {
        "duration": "PT15S",
        "iops": {
          "read": "200",
          "total": "1000",
          "write": "100"
        "latency": {
          "read": "200",
          "total": "1000",
          "write": "100"
        "status": "ok",
        "throughput": {
          "read": "200",
          "total": "1000",
          "write": "100"
        "timestamp": "2017-01-25T11:20:13Z"
      "name": "node1_aggr_1",
      "node": {
        "name": "node1",
      "snaplock_type": "string",
      "space": {
        "block_storage": {
          "available": "10156560384",
          "full_threshold_percent": 0,
          "inactive_user_data": "304448",
          "size": "10156769280",
          "used": "2088960"
        "cloud_storage": {
          "used": "402743264"
        "efficiency": {
          "logical_used": 0,
          "ratio": 0,
          "savings": 0
        "efficiency_without_snapshots": {
          "logical_used": 0,
          "ratio": 0,
          "savings": 0
        "footprint": "608896"
      "state": "string",
      "statistics": {
        "iops_raw": {
          "read": "200",
          "total": "1000",
          "write": "100"
        "latency_raw": {
          "read": "200",
          "total": "1000",
          "write": "100"
        "status": "ok",
        "throughput_raw": {
          "read": "200",
          "total": "1000",
          "write": "100"
      "uuid": "string"
  "spares": [
      "disk_class": "solid_state",
      "layout_requirements": [
          "aggregate_min_disks": "6",
          "raid_group": {
            "default": "16",
            "max": "28",
            "min": "5"
      "node": {
        "name": "node1",
      "syncmirror_pool": "string",
      "usable": "9"
Status: Default
ONTAP Error Response Codes
Error Code Description
787092
The target field cannot be specified for this operation.
8586225
Encountered unexpected error in retrieving metrics and statistics for an aggregate.
19726341
Not enough eligible spare disks are available on the node.
19726344
No recommendation can be made for this cluster.
19726357
Aggregate recommendations are not supported on MetroCluster.
19726358
Aggregate recommendations are not supported on ONTAP Cloud.
19726382
Another provisioning operation is in progress on this cluster. Wait a few minutes, and try the operation again.
19726386
Encountered an error when retrieving licensing information on this cluster.
19726387
No recommendation can be provided for this cluster within the license capacity.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
self
hybrid_cache
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs.
disk_count
integer
Number of disks used in the cache tier of the aggregate. Only provided when hybrid_cache.enabled is 'true'.
enabled
boolean
Specifies whether the aggregate uses HDDs with SSDs as a cache.
raid_type
string
RAID type for SSD cache of the aggregate. Only provided when hybrid_cache.enabled is 'true'.
size
integer
Total usable space in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'.
used
integer
Space used in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'.
mirror
enabled
boolean
Aggregate is SyncMirror protected
state
string
plex_reference
Plex
_links
_links
name
string
primary
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details.
checksum_style
string
The checksum style used by the aggregate.
disk_class
string
The class of disks being used by the aggregate.
disk_count
integer
Number of disks used in the aggregate. This includes parity disks, but excludes disks in the hybrid cache.
disk_type
string
The type of disk being used by the aggregate.
raid_size
integer
Option to specify the maximum number of disks that can be included in a RAID group.
raid_type
string
RAID type of the aggregate.
block_storage
Configuration information for the locally attached portion of the aggregate. When a cloud store is also used by this aggregate, this is referred to as the performance tier.
hybrid_cache
hybrid_cache
mirror
mirror
plexes
array[plex_reference]
Plex reference for each plex in the aggregate.
primary
primary
cloud_store
Cloud store
_links
_links
name
string
uuid
string
cloud_storage_tier
cloud_store
cloud_store
Cloud store
used
integer
Capacity used in bytes in the cloud store by this aggregate. This is a cached value calculated every 5 minutes.
cloud_storage
Configuration information for the cloud storage portion of the aggregate. This is referred to as the capacity tier.
attach_eligible
boolean
Specifies whether the aggregate is eligible for a cloud store to be attached.
stores
array[cloud_storage_tier]
Configuration information for each cloud storage portion of the aggregate.
tiering_fullness_threshold
integer
The percentage of space in the performance tier that must be used before data is tiered out to the cloud store. Only valid for PATCH operations.
data_encryption
boolean
Specifies whether the aggregate uses self-encrypting drives with data protection enabled.
boolean
Specifies whether NetApp aggregate encryption is enabled. All data in the aggregate is encrypted.
dr_home_node
Node where the aggregate resides after disaster recovery. The value for this field might differ from the 'node' field during switchover.
name
string
uuid
string
home_node
Node where the aggregate resides after giveback. The value for this field might differ from the value of the 'node' field during takeover.
_links
_links
name
string
uuid
string
enabled
boolean
Specifes whether or not inactive data reporting is enabled on the aggregate.
start_time
string
Timestamp at which inactive data reporting was enabled on the aggregate.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
other
integer
read
integer
total
integer
write
integer
metric
The most recent sample of I/O metrics for the aggregate.
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
node
Node where the aggregate currently resides.
_links
_links
name
string
uuid
string
block_storage
available
integer
Space available in bytes.
integer
The aggregate used percentage at which 'monitor.volume.full' EMS is generated.
inactive_user_data
integer
The size that is physically used in the block storage and has a cold temperature, in bytes. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data or **.
size
integer
Total usable space in bytes, not including WAFL reserve and aggregate Snapshot copy reserve.
used
integer
Space used or reserved in bytes. Includes volume guarantees and aggregate metadata.
cloud_storage
used
integer
Used space in bytes in the cloud store. Only applicable for aggregates with a cloud store tier.
efficiency
Storage efficiency
logical_used
integer
Logical used
ratio
number
Data reduction ratio (logical_used / used)
savings
integer
Space saved by storage efficiencies (logical_used - used)
Storage efficiency that does not include the savings provided by Snapshot copies.
logical_used
integer
Logical used
ratio
number
savings
integer
space
block_storage
block_storage
cloud_storage
cloud_storage
efficiency
efficiency
Storage efficiency
footprint
integer
A summation of volume footprints (including volume guarantees), in bytes. This includes all of the volume footprints in the block_storage tier and the cloud_storage tier. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other
integer
read
integer
total
integer
write
integer
statistics
The real time I/O statistics for the aggregate.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
aggregate
_links
_links
block_storage
block_storage
cloud_storage
cloud_storage
create_time
string
Timestamp of aggregate creation
data_encryption
data_encryption
dr_home_node
dr_home_node
home_node
home_node
metric
metric
name
string
Aggregate name
node
node
snaplock_type
string
SnapLock type
space
space
state
string
Operational state of the aggregate
statistics
statistics
uuid
string
Aggregate UUID
raid_group
default
integer
Default number of disks in a RAID group
max
integer
Maximum number of disks allowed in a RAID group
min
integer
Minimum number of disks allowed in a RAID group
layout_requirement
aggregate_min_disks
integer
Minimum number of disks to create an aggregate
default
boolean
Indicates if this RAID type is the default
raid_group
raid_group
raid_type
string
RAID type
node
Node where the spares are assigned
_links
_links
name
string
uuid
string
aggregate_spare
checksum_style
string
The checksum type that has been assigned to the spares
disk_class
string
Disk class of spares
layout_requirements
array[layout_requirement]
Available RAID protections and their restrictions
node
node
size
integer
Usable size of each spare in bytes
syncmirror_pool
string
SyncMirror spare pool
usable
integer
Total number of usable spares in the bucket. The usable count for each class of spares does not include reserved spare capacity recommended by ONTAP best practices.
  • example: 9
  • readOnly: 1
  • Introduced in: 9.6
