Retrieve a FlexCache volume in the cluster
GET /storage/flexcache/flexcaches
Introduced In: 9.6
Retrieves FlexCache in the cluster.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
origins.ip_address- IP address of origin. -
origins.size- Physical size of origin. -
origins.state- State of origin. -
size- Physical size of FlexCache. -
guarantee.type- Space guarantee style of FlexCache. -
aggregates.nameoraggregates.uuid- Name or UUID of aggregrate of FlexCache volume. -
path- Fully-qualified path of the owning SVM's namespace where the FlexCache is mounted.
Related ONTAP commands
volume flexcache show
Learn more
uuid |
string |
query |
False |
Filter by uuid |
aggregates.uuid |
string |
query |
False |
Filter by aggregates.uuid |
aggregates.name |
string |
query |
False |
Filter by aggregates.name |
constituents_per_aggregate |
integer |
query |
False |
Filter by constituents_per_aggregate |
origins.svm.uuid |
string |
query |
False |
Filter by origins.svm.uuid |
origins.svm.name |
string |
query |
False |
Filter by origins.svm.name |
origins.state |
string |
query |
False |
Filter by origins.state |
origins.ip_address |
string |
query |
False |
Filter by origins.ip_address |
origins.cluster.name |
string |
query |
False |
Filter by origins.cluster.name |
origins.cluster.uuid |
string |
query |
False |
Filter by origins.cluster.uuid |
origins.size |
integer |
query |
False |
Filter by origins.size |
origins.volume.uuid |
string |
query |
False |
Filter by origins.volume.uuid |
origins.volume.name |
string |
query |
False |
Filter by origins.volume.name |
origins.create_time |
string |
query |
False |
Filter by origins.create_time |
name |
string |
query |
False |
Filter by name |
lock_consistent_when_disconnected |
boolean |
query |
False |
Filter by lock_consistent_when_disconnected
size |
integer |
query |
False |
Filter by size |
path |
string |
query |
False |
Filter by path |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
use_tiered_aggregate |
boolean |
query |
False |
Filter by use_tiered_aggregate
guarantee.type |
string |
query |
False |
Filter by guarantee.type
return_timeout |
integer |
query |
False |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
return_records |
boolean |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[flexcache] |
"next": {
"href": "/api/resourcelink"
"records": [
"aggregates": [
"name": "aggr1",
"guarantee": {
"type": "string"
"name": "vol1",
"origins": [
"cluster": {
"name": "cluster1",
"create_time": "2018-06-04T19:00:00Z",
"ip_address": "10.10.10.7",
"size": 0,
"state": "string",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"path": "/user/my_fc",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
aggregates
Aggregate
_links |
name |
string |
uuid |
string |
guarantee
type |
string |
The type of space guarantee of this volume in the aggregate. |
cluster
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
flexcache_relationship
cluster |
create_time |
string |
Creation time of the relationship. |
ip_address |
string |
Cluster managerment IP of the remote cluster. |
size |
integer |
Size of the remote volume. |
state |
string |
Volume state |
svm |
volume |
svm
FlexCache SVM
_links |
name |
string |
uuid |
string |
flexcache
Defines the cache endpoint of FlexCache.
_links |
aggregates |
array[aggregates] |
integer |
Number of FlexCache constituents per aggregate when the 'aggregates' field is mentioned. |
guarantee |
boolean |
Specifies if the origin will honor the cache side locks when doing the lock checks in the disconnected mode. The default value will be set to false to allow origin to skip such lock checks with the disconnected cache and go ahead with processing of the conflicting locks. If set to true the origin denies the lock operation (open or byte-range) if it conflicts with the authority granted to the disconnected cache. |
name |
string |
FlexCache name |
origins |
array[flexcache_relationship] |
path |
string |
The fully-qualified path in the owning SVM's namespace at which the FlexCache is mounted. The path is case insensitive and must be unique within a SVM's namespace. Path must begin with '/' and must not end with '/'. Only one FlexCache be mounted at any given junction path. |
size |
integer |
Physical size of the FlexCache. The recommended size for a FlexCache is 10% of the origin volume. The minimum FlexCache constituent size is 1GB. |
svm |
FlexCache SVM |
boolean |
Specifies whether or not a Fabricpool-enabled aggregate can be used in FlexCache creation. The use_tiered_aggregate is only used when auto-provisioning a FlexCache volume. |
uuid |
string |
FlexCache UUID. Unique identifier for the FlexCache. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
