REST API reference
Retrieve the origin of a FlexCache volume in the cluster
GET /storage/flexcache/origins
Introduced In: 9.6
Retrieves origin of FlexCache in the cluster.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • flexcaches.ip_address - IP address of FlexCache.
  • flexcaches.size - Physical size of FlexCache.
  • flexcaches.guarantee.type - Space guarantee style of FlexCache.
  • flexcaches.state - State of FlexCache.
  • volume flexcache origin show-caches
uuid
string
query
False
Filter by uuid
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
flexcaches.svm.uuid
string
query
False
Filter by flexcaches.svm.uuid
flexcaches.svm.name
string
query
False
Filter by flexcaches.svm.name
flexcaches.state
string
query
False
Filter by flexcaches.state
string
query
False
Filter by flexcaches.ip_address
flexcaches.cluster.name
string
query
False
Filter by flexcaches.cluster.name
flexcaches.cluster.uuid
string
query
False
Filter by flexcaches.cluster.uuid
flexcaches.size
integer
query
False
Filter by flexcaches.size
flexcaches.volume.uuid
string
query
False
Filter by flexcaches.volume.uuid
flexcaches.volume.name
string
query
False
Filter by flexcaches.volume.name
flexcaches.create_time
string
query
False
Filter by flexcaches.create_time
name
string
query
False
Filter by name
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
return_records
boolean
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[flexcache_origin]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "flexcaches": [
          "cluster": {
            "name": "cluster1",
          "create_time": "2018-06-04T19:00:00Z",
          "ip_address": "10.10.10.7",
          "size": 0,
          "state": "string",
          "svm": {
            "name": "svm1",
          "volume": {
            "name": "volume1",
      "name": "vol1, vol_2",
      "svm": {
        "name": "svm1",
      "uuid": "1cd8a442-86d1-11e0-ae1c-123478563512"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
cluster
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
flexcache_relationship
cluster
cluster
create_time
string
Creation time of the relationship.
ip_address
string
Cluster managerment IP of the remote cluster.
size
integer
Size of the remote volume.
state
string
Volume state
svm
svm
volume
volume
svm
Origin volume SVM
_links
_links
name
string
uuid
string
flexcache_origin
Defines the origin endpoint of FlexCache.
_links
_links
flexcaches
array[flexcache_relationship]
name
string
Origin volume name
svm
svm
Origin volume SVM
uuid
string
Origin volume UUID. Unique identifier for origin of FlexCache.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
