REST API reference
Retrieve a QoS policy
GET /storage/qos/policies/{uuid}
Introduced In: 9.6
Retrieves a specific QoS policy.
  • qos policy-group show
  • qos adaptive-policy-group show
uuid
string
path
True
  • Introduced in: 9.8
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
adaptive
adaptive
Adaptive QoS policy-groups define measurable service level objectives (SLOs) that adjust based on the storage object used space and the storage object allocated space.
fixed
fixed
QoS policy-groups define a fixed service level objective (SLO) for a storage object.
name
string
Name of the QoS policy.
object_count
integer
Number of objects attached to this policy.
svm
svm
uuid
string
      "href": "/api/resourcelink"
  "name": "extreme",
  "object_count": 0,
  "svm": {
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
adaptive
absolute_min_iops
integer
Specifies the absolute minimum IOPS that is used as an override when the expected_iops is less than this value. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
expected_iops
integer
Expected IOPS. Specifies the minimum expected IOPS per TB allocated based on the storage object allocated size. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
peak_iops
integer
Peak IOPS. Specifies the maximum possible IOPS per TB allocated based on the storage object allocated size or the storage object used size.
fixed
capacity_shared
boolean
Specifies whether the capacities are shared across all objects that use this QoS policy-group. Default is false.
max_throughput_iops
integer
Maximum throughput defined by this policy. It is specified in terms of IOPS. 0 means no maximum throughput is enforced.
max_throughput_mbps
integer
Maximum throughput defined by this policy. It is specified in terms of Mbps. 0 means no maximum throughput is enforced.
min_throughput_iops
integer
Minimum throughput defined by this policy. It is specified in terms of IOPS. 0 means no minimum throughput is enforced. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
min_throughput_mbps
integer
Minimum throughput defined by this policy. It is specified in terms of Mbps. 0 means no minimum throughput is enforced.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
