REST API reference
Retrieve the quota report records for all FlexVol and FlexGroup volumes
GET /storage/quota/reports
Introduced In: 9.6
Retrieves the quota report records for all FlexVol volumes and FlexGroup volumes.
  • quota report
users.id
string
query
False
Filter by users.id
users.name
string
query
False
Filter by users.name
space.used.soft_limit_percent
integer
query
False
Filter by space.used.soft_limit_percent
space.used.total
integer
query
False
Filter by space.used.total
space.used.hard_limit_percent
integer
query
False
Filter by space.used.hard_limit_percent
space.hard_limit
integer
query
False
Filter by space.hard_limit
space.soft_limit
integer
query
False
Filter by space.soft_limit
type
string
query
False
Filter by type
volume.uuid
string
query
False
Filter by volume.uuid
volume.name
string
query
False
Filter by volume.name
group.name
string
query
False
Filter by group.name
group.id
string
query
False
Filter by group.id
qtree.id
integer
query
False
Filter by qtree.id
qtree.name
string
query
False
Filter by qtree.name
files.soft_limit
integer
query
False
Filter by files.soft_limit
files.hard_limit
integer
query
False
Filter by files.hard_limit
files.used.soft_limit_percent
integer
query
False
Filter by files.used.soft_limit_percent
files.used.total
integer
query
False
Filter by files.used.total
files.used.hard_limit_percent
integer
query
False
Filter by files.used.hard_limit_percent
index
integer
query
False
Filter by index
specifier
string
query
False
Filter by specifier
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
show_default_records
boolean
query
False
The default is true for GET calls. When set to false, the default records are not reported.
  • Introduced in: 9.7
  • Default value: 1
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[quota_report]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "files": {
        "hard_limit": 0,
        "soft_limit": 0,
        "used": {
          "hard_limit_percent": 0,
          "soft_limit_percent": 0,
          "total": 0
      "group": {
        "id": "string",
        "name": "string"
      "index": 0,
      "qtree": {
        "id": "1",
        "name": "qt1"
      "space": {
        "hard_limit": 0,
        "soft_limit": 0,
        "used": {
          "total": 0
      "specifier": "string",
      "svm": {
        "name": "svm1",
      "type": "string",
      "users": [
          "id": "string",
          "name": "string"
      "volume": {
        "name": "volume1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
used
hard_limit_percent
integer
Total files used as a percentage of file hard limit
soft_limit_percent
integer
Total files used as a percentage of file soft limit
total
integer
Total files used
files
hard_limit
integer
File hard limit
soft_limit
integer
File soft limit
used
used
group
This parameter specifies the target group associated with the given quota report record. This parameter is available for group quota records and is not available for user or tree quota records. The target group is identified by a UNIX group name and UNIX group identifer.
id
string
Quota target group ID
name
string
Quota target group name
qtree
This parameter specifies the target qtree to which the user/group/tree quota policy rule applies. For a user/group quota policy rule at qtree level, this parameter takes a qtree name and is valid in GET or POST. For a user/group quota policy rule at volume level, this parameter is not valid in GET or POST. For a tree quota policy rule, this parameter is mandatory and is valid in both POST and GET. For a default tree quota policy rule, this parameter needs to be specified as "". For a tree quota policy rule at qtree level, this parameter takes a qtree name and is valid in GET or POST.
_links
_links
id
integer
The unique identifier for a qtree.
name
string
The name of the qtree.
used
hard_limit_percent
integer
Total space used as a percentage of space hard limit
soft_limit_percent
integer
Total space used as a percentage of space soft limit
total
integer
Total space used
space
hard_limit
integer
Space hard limit in bytes
soft_limit
integer
Space soft limit in bytes
used
used
svm
_links
_links
name
string
The name of the SVM.
uuid
string
users
id
string
Quota target user ID
name
string
Quota target user name
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
quota_report
_links
_links
files
files
group
group
index
integer
Index that identifies a unique quota record. Valid in URL.
qtree
qtree
space
space
specifier
string
Quota specifier
svm
svm
type
string
Quota type associated with the quota record.
users
array[users]
This parameter specifies the target user or users associated with the given quota report record. This parameter is available for user quota records and is not available for group or tree quota records. The target user or users are identified by a user name and user identifier. The user name can be a UNIX user name or a Windows user name, and the identifer can be a UNIX user identifier or a Windows security identifier.
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
