Retrieve event retention policies for an SVM
GET /storage/snaplock/event-retention/policies
Introduced In: 9.7
Retrieves all event retention policies for an SVM.
Related ONTAP commands
snaplock event-retention policy show
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_timeout  |
integer  |
query  |
False  |
return_records  |
boolean  |
query  |
False  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of records  |
records  |
array[snaplock_retention_policy]  |
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "name": "string",
      "retention_period": "P30M",
      "svm": {
        "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
_links  |
name  |
string  |
Specifies the EBR policy name  |
retention_period  |
string  |
Specifies the retention period of an event based retention policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "P  |
svm  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
