Retrieve the status of legal-hold for an operation ID
GET /storage/snaplock/litigations/{litigation.id}/operations/{id}
Introduced In: 9.7
Retrieves the status of legal-hold for the specified operation ID.
Related ONTAP commands
snaplock legal-hold show
litigation.id  |
string  |
path  |
True  |
Litigation ID  |
id  |
string  |
path  |
True  |
Operation ID.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
id  |
integer  |
Operation ID.  |
num_files_failed  |
string  |
Specifies the number of files on which legal-hold operation failed.  |
num_files_processed  |
string  |
Specifies the number of files on which legal-hold operation was successful.  |
num_files_skipped  |
string  |
Specifies the number of files on which legal-hold begin operation was skipped. The legal-hold begin operation is skipped on a file if it is already under hold for a given litigation.  |
num_inodes_ignored  |
string  |
Specifies the number of inodes on which the legal-hold operation was not attempted because they were not regular files.  |
path  |
string  |
Specifies the path on which legal-hold operation is applied.  |
state  |
string  |
Specifies the status of legal-hold operation.  |
type  |
string  |
Specifies the type of legal-hold operation.  |
      "href": "/api/resourcelink"
  "id": "16842759",
  "num_files_failed": "0",
  "num_files_processed": "30",
  "num_files_skipped": "10",
  "num_inodes_ignored": "10",
  "path": "/dir1",
  "state": "completed",
  "type": "begin"
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090346  |
Internal Error. Wait a few minutes, then try the command again  |
14090343  |
Invalid Field  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
