REST API reference
Retrieve litigations under an SVM
GET /storage/snaplock/litigations
Introduced In: 9.7
Retrieves the list of litigations under an SVM.
  • snaplock legal-hold show
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of Records
records
array[snaplock_litigation]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "id": "string",
      "name": "lit1",
      "operations": [
          "id": "16842759",
          "num_files_failed": "0",
          "num_files_processed": "30",
          "num_files_skipped": "10",
          "num_inodes_ignored": "10",
          "path": "/dir1",
          "state": "completed",
          "type": "begin"
      "svm": {
        "name": "svm1",
      "volume": {
        "name": "volume1",
Status: Default
ONTAP Error Response codes
Error code Description
14090346
Internal Error. Wait a few minutes, then try the command again
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
_links
_links
id
integer
Operation ID.
num_files_failed
string
Specifies the number of files on which legal-hold operation failed.
num_files_processed
string
Specifies the number of files on which legal-hold operation was successful.
num_files_skipped
string
Specifies the number of files on which legal-hold begin operation was skipped. The legal-hold begin operation is skipped on a file if it is already under hold for a given litigation.
num_inodes_ignored
string
Specifies the number of inodes on which the legal-hold operation was not attempted because they were not regular files.
path
string
Specifies the path on which legal-hold operation is applied.
state
string
Specifies the status of legal-hold operation.
type
string
Specifies the type of legal-hold operation.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
snaplock_litigation
_links
_links
id
string
Specifies the litigation ID.
name
string
Specifies the legal-hold litigation name.
operations
array[snaplock_legal_hold_operation]
svm
svm
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
