Retrieve Snapshot copy policy schedules
GET /storage/snapshot-policies/{snapshot_policy.uuid}/schedules
Introduced In: 9.8
Retrieves a collection of Snapshot copy policy schedules.
Related ONTAP commands
snapshot policy show
snapshot_policy.uuid |
string |
path |
True |
Snapshot copy policy UUID |
prefix |
string |
query |
False |
Filter by prefix |
count |
integer |
query |
False |
Filter by count |
schedule.name |
string |
query |
False |
Filter by schedule.name |
schedule.uuid |
string |
query |
False |
Filter by schedule.uuid |
snapshot_policy.name |
string |
query |
False |
Filter by snapshot_policy.name |
string |
query |
False |
Filter by snapshot_policy.uuid |
snapmirror_label |
string |
query |
False |
Filter by snapmirror_label |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[snapshot_policy_schedule] |
"next": {
"href": "/api/resourcelink"
"records": [
"prefix": "string",
"schedule": {
"name": "weekly",
"snapmirror_label": "string",
"snapshot_policy": {
"name": "default",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
schedule
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
snapshot_policy
This is a reference to the Snapshot copy policy.
_links |
name |
string |
uuid |
string |
The Snapshot copy policy schedule object is associated with a Snapshot copy policy and it defines the interval at which Snapshot copies are created and deleted.
_links |
count |
integer |
The number of Snapshot copies to maintain for this schedule. |
prefix |
string |
The prefix to use while creating Snapshot copies at regular intervals. |
schedule |
snapmirror_label |
string |
Label for SnapMirror operations |
snapshot_policy |
This is a reference to the Snapshot copy policy. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
