REST API reference
Retrieve a collection of event destinations
GET /support/ems/destinations
Introduced In: 9.6
Retrieves a collection of event destinations.
  • event notification destination show
  • event notification show
certificate.ca
string
query
False
Filter by certificate.ca
certificate.serial_number
string
query
False
Filter by certificate.serial_number
name
string
query
False
Filter by name
filters.name
string
query
False
Filter by filters.name
type
string
query
False
Filter by type
destination
string
query
False
Filter by destination
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": "3",
  "records": [
      "certificate": {
        "ca": "VeriSign",
        "serial_number": "1234567890"
      "destination": "administrator@mycompany.com",
      "filters": [
          "name": "important-events"
      "name": "Admin_Email",
      "type": "email"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
certificate
Certificate information is valid for the "rest_api" type.
ca
string
Client certificate issuing CA
serial_number
string
Client certificate serial number
filters
_links
_links
name
string
records
_links
_links
certificate
certificate
destination
string
Event destination
filters
array[filters]
name
string
Destination name. Valid in POST.
type
string
Type of destination. Valid in POST.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
