Retrieve an event filter
GET /support/ems/filters/{name}
Introduced In: 9.6
Retrieves an event filter.
Related ONTAP commands
event filter show
name  |
string  |
path  |
True  |
Filter name  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
name  |
string  |
Filter name  |
rules  |
array[rules]  |
Array of event filter rules on which to match.  |
      "href": "/api/resourcelink"
  "name": "snmp-traphost",
  "rules": [
      "index": "1",
      "message_criteria": {
          "related": {
        "name_pattern": "callhome.*",
        "severities": "error,informational",
        "snmp_trap_types": "standard|built_in"
      "type": "include"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
_links
related  |
message_criteria
Matching message definitions for the filter. A property must be specified.
_links  |
name_pattern  |
string  |
Message name filter on which to match. Supports wildcards. Defaults to * if not specified.  |
severities  |
string  |
A comma-separated list of severities or a wildcard.  |
snmp_trap_types  |
string  |
A comma separated list of snmp_trap_types or a wildcard.  |
rules
Rule for an event filter
_links  |
index  |
integer  |
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list.  |
message_criteria  |
Matching message definitions for the filter. A property must be specified.  |
type  |
string  |
Rule type  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
