Update the cluster software version
PATCH /cluster/software
Introduced In: 9.6
Updates the cluster software version. Important note:
Setting 'version' triggers the package installation.
To validate the package for installation but not perform the installation, use the
validate_onlyfield on the request.
Required properties
version- Software version to be installed on the cluster.
Recommended optional parameters
validate_only- Required to validate a software package before an upgrade. -
skip_warnings- Used to skip validation warnings when starting a software upgrade. -
action- Used to pause, resume, or cancel an ongoing software upgrade. -
stabilize_minutes- Specifies a custom value between 1 to 60 minutes that allows each node a specified amount of time to stabilize after a reboot; the default is 8 minutes.
Related ONTAP commands
cluster image validate -
cluster image update -
cluster image pause-update -
cluster image resume-update -
cluster image cancel-update
Learn more
skip_warnings  |
boolean  |
query  |
False  |
Ignore warnings and proceed with the install.  |
action  |
string  |
query  |
False  |
Requests an upgrade to pause, resume, or cancel.
Note that not all upgrades support these actions. An upgrade can only be resumed if it is in the paused state. When a request to cancel an upgrade is successful, the upgrade state changes to either
stabilize_minutes  |
integer  |
query  |
False  |
Sets a custom value between 1 to 60 minutes for the upgrade, allowing each node a specified amount of time to stabilize after a reboot.
return_records  |
boolean  |
query  |
False  |
return_timeout  |
integer  |
query  |
False  |
validate_only  |
boolean  |
query  |
False  |
Validate the operation and its parameters, without actually performing the operation.  |
Request Body
| Name | Type | Description |
action  |
string  |
User triggered action to apply to the install operation  |
elapsed_duration  |
integer  |
Elapsed time during the upgrade or validation operation  |
estimated_duration  |
integer  |
Estimated time remaining until completion of the upgrade or validation operation.  |
metrocluster  |
nodes  |
array[software_node_reference]  |
List of nodes and active versions.  |
pending_version  |
string  |
Version being installed on the system.
state  |
string  |
Operational state of the upgrade  |
status_details  |
Display status details.  |
update_details  |
Display update progress details.  |
validation_results  |
List of validation warnings, errors, and advice.  |
version  |
string  |
Version of ONTAP installed and currently active on the system. During PATCH, using the 'validate_only' parameter on the request executes pre-checks, but does not perform the full installation.
Example request
  "action": "pause",
  "elapsed_duration": "2140",
  "estimated_duration": "5220",
  "metrocluster": {
    "clusters": [
        "estimated_duration": "3480",
        "name": "cluster_A",
        "state": "in_progress"
    "progress_details": {
      "message": "Switchover in progress"
    "progress_summary": {
      "message": "MetroCluster updated successfully."
  "nodes": [
      "name": "node1",
      "version": "ONTAP_X"
  "pending_version": "ONTAP_X_1",
  "state": "completed",
  "status_details": [
      "action": {
        "message": "string"
      "end_time": "2019-02-02T19:00:00Z",
      "issue": {
        "code": "10551399",
        "message": "Image update complete"
      "name": "initialize",
      "node": {
        "name": "node1"
      "start_time": "2019-02-02T19:00:00Z",
      "state": "failed"
  "update_details": [
      "elapsed_duration": "2100",
      "estimated_duration": "4620",
      "node": {
        "name": "node1"
      "phase": "Pre-update checks",
      "state": "failed"
  "validation_results": [
      "action": {
        "message": "string"
      "issue": {
        "message": "Validation error: Cluster HA is not configured in the cluster"
      "status": "warning",
      "update_check": "nfs_mounts"
Status: 202, Accepted
job  |
  "job": {
    "uuid": "string"
Status: Default, Error
href  |
string  |
_links
software_mcc_reference
elapsed_duration  |
integer  |
Elapsed duration of update time (in seconds) of MetroCluster.  |
integer  |
Estimated duration of update time (in seconds) of MetroCluster.  |
name  |
string  |
Name of the site in MetroCluster.  |
state  |
Upgrade state of MetroCluster.  |
progress_details
message  |
string  |
MetroCluster update progress details.  |
progress_summary
message  |
string  |
MetroCluster update progress summary.  |
metrocluster
clusters  |
array[software_mcc_reference]  |
List of MetroCluster sites, statuses, and active ONTAP versions.
progress_details  |
progress_summary  |
name  |
string  |
Name of the node.  |
version  |
string  |
ONTAP version of the node.
action
code  |
integer  |
Error code corresponding the status error  |
message  |
string  |
Corrective action to be taken to resolve the status error.  |
issue
code  |
integer  |
Error code corresponding to update status  |
message  |
string  |
Update status details  |
node
name  |
string  |
Name of the node to be retrieved for status details.  |
software_status_details_reference
action  |
end_time  |
string  |
End time for each status phase.  |
issue  |
name  |
string  |
Name of the phase to be retrieved for status details.  |
node  |
start_time  |
string  |
Start time for each status phase.  |
state  |
string  |
Status of the phase  |
node
name  |
string  |
Name of the node to be retrieved for update details.  |
software_update_details_reference
elapsed_duration  |
integer  |
Elapsed duration for each update phase  |
integer  |
Estimated duration for each update phase  |
node  |
phase  |
string  |
Phase details  |
state  |
string  |
State of the update phase  |
action
message  |
string  |
Specifies the corrective action to be taken to resolve a validation error  |
issue
message  |
string  |
Details of the error or warning encountered by the update checks  |
software_validation_reference
action  |
issue  |
status  |
string  |
Status of this update check.  |
update_check  |
string  |
Name of the update check to be validated.  |
software_reference
action  |
string  |
elapsed_duration  |
integer  |
integer  |
metrocluster  |
nodes  |
pending_version  |
string  |
state  |
string  |
status_details  |
update_details  |
version  |
string  |
job_link
uuid  |
string  |
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
