Update an Ethernet switch
PATCH /network/ethernet/switches/{name}
Introduced In: 9.8
Update Ethernet Switch REST API
name |
string |
path |
True |
Switch Name |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
address |
string |
IP Address. |
discovered |
boolean |
Discovered By ONTAP CDP/LLDP
model |
string |
Model Number. |
monitoring |
name |
string |
Name. |
network |
string |
Switch Network. |
serial_number |
string |
Serial Number. |
snmp |
version |
string |
Software Version. |
Example request
"address": "string",
"model": "string",
"monitoring": {
"reason": "string"
"name": "string",
"network": "string",
"serial_number": "string",
"snmp": {
"user": "string",
"version": "string"
"version": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default, Error
href |
string |
self_link
monitoring
enabled |
boolean |
Enable Health Monitoring. |
monitored |
boolean |
Is Monitored. |
reason |
string |
Reason For Not Monitoring. |
snmp
user |
string |
Community String or SNMPv3 Username. |
version |
string |
SNMP Version. |
switch
address |
string |
IP Address. |
discovered |
boolean |
model |
string |
Model Number. |
monitoring |
name |
string |
Name. |
network |
string |
Switch Network. |
serial_number |
string |
Serial Number. |
snmp |
version |
string |
Software Version. |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
