Update a service policy for network interfaces
PATCH /network/ip/service-policies/{uuid}
Introduced In: 9.8
Updates a service policy for network interfaces.
uuid |
string |
path |
True |
UUID of the service policy |
Request Body
| Name | Type | Description |
name |
string |
services |
array[string] |
uuid |
string |
Example request
"name": "default-intercluster",
"services": [
"data_nfs"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
53281929 |
Service policies cannot combine block and file services. |
53281930 |
Service policies maintained by the system cannot be renamed. |
53281931 |
Service policy names cannot start with "default-". |
53281933 |
A Cluster-scoped service cannot be added to a SVM-scoped service policy. |
53281934 |
An SVM-scoped service cannot be added to a Cluster-scoped service policy. |
href |
string |
_links
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
name |
string |
The name of the SVM. |
uuid |
string |
ip_service_policy
name |
string |
services |
array[string] |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
