REST API reference
Update CIFS mandatory and optional parameters
PATCH /protocols/cifs/services/{svm.uuid}
Introduced In: 9.6
Updates both the mandatory and optional parameters of the CIFS configuration. Ensure the CIFS server is administratively disabled when renaming the CIFS server or modifying the ad_domain properties.
  • vserver cifs server modify
  • vserver cifs server options modify
  • vserver cifs security modify
  • vserver cifs server add-netbios-aliases
  • vserver cifs server remove-netbios-aliases
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
svm.uuid
string
path
True
Request Body
Name Type Description
ad_domain
ad_domain
comment
string
A descriptive text comment for the CIFS server. SMB clients can see the CIFS server comment when browsing servers on the network. If there is a space in the comment, you must enclose the entire string in quotation marks.
default_unix_user
string
Specifies the UNIX user to which any authenticated CIFS user is mapped to, if the normal user mapping rules fails.
enabled
boolean
Specifies if the CIFS service is administratively enabled.
metric
metric
name
string
The name of the CIFS server.
netbios
cifs_netbios
security
cifs_service_security
statistics
statistics
svm
svm
Example request
  "ad_domain": {
    "fqdn": "example.com",
    "organizational_unit": "string",
    "password": "string"
  "comment": "This CIFS Server Belongs to CS Department",
  "default_unix_user": "string",
  "metric": {
    "duration": "PT15S",
    "iops": {
      "read": "200",
      "total": "1000",
      "write": "100"
    "latency": {
      "read": "200",
      "total": "1000",
      "write": "100"
    "status": "ok",
    "throughput": {
      "read": "200",
      "total": "1000",
      "write": "100"
    "timestamp": "2017-01-25T11:20:13Z"
  "name": "CIFS1",
  "netbios": {
    "aliases": [
      "ALIAS_1",
      "ALIAS_2",
      "ALIAS_3"
    "wins_servers": [
      "10.224.65.20",
      "10.224.65.21"
  "security": {
    "restrict_anonymous": "string"
  "statistics": {
    "iops_raw": {
      "read": "200",
      "total": "1000",
      "write": "100"
    "latency_raw": {
      "read": "200",
      "total": "1000",
      "write": "100"
    "status": "ok",
    "throughput_raw": {
      "read": "200",
      "total": "1000",
      "write": "100"
  "svm": {
    "name": "svm1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default, Error
string
ad_domain
fqdn
string
The fully qualified domain name of the Windows Active Directory to which this CIFS server belongs. A CIFS server appears as a member of Windows server object in the Active Directory store. POST and PATCH only.
organizational_unit
string
Specifies the organizational unit within the Active Directory domain to associate with the CIFS server. POST and PATCH only.
password
string
The account password used to add this CIFS server to the Active Directory. This is not audited.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
metric
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
cifs_netbios
aliases
array[string]
enabled
boolean
Specifies whether NetBios name service (NBNS) is enabled for the CIFS. If this service is enabled, the CIFS server will start sending the broadcast for name registration.
wins_servers
array[string]
encrypt_dc_connection
boolean
Specifies whether encryption is required for domain controller connections.
kdc_encryption
boolean
Specifies whether AES-128 and AES-256 encryption is enabled for all Kerberos-based communication with the Active Directory KDC. To take advantage of the strongest security with Kerberos-based communication, AES-256 and AES-128 encryption can be enabled on the CIFS server. Kerberos-related communication for CIFS is used during CIFS server creation on the SVM, as well as during the SMB session setup phase. The CIFS server supports the following encryption types for Kerberos communication:
  • RC4-HMAC
  • DES
  • AES When the CIFS server is created, the domain controller creates a computer machine account in Active Directory. After a newly created machine account authenticates, the KDC and the CIFS server negotiates encryption types. At this time, the KDC becomes aware of the encryption capabilities of the particular machine account and uses those capabilities in subsequent communication with the CIFS server. In addition to negotiating encryption types during CIFS server creation, the encryption types are renegotiated when a machine account password is reset.
restrict_anonymous
string
Specifies what level of access an anonymous user is granted. An anonymous user (also known as a "null user") can list or enumerate certain types of system information from Windows hosts on the network, including user names and details, account policies, and share names. Access for the anonymous user can be controlled by specifying one of three access restriction settings. The available values are:
  • no_restriction - No access restriction for an anonymous user.
  • no_enumeration - Enumeration is restricted for an anonymous user.
  • no_access - All access is restricted for an anonymous user.
smb_encryption
boolean
Specifies whether encryption is required for incoming CIFS traffic.
smb_signing
boolean
Specifies whether signing is required for incoming CIFS traffic. SMB signing helps to ensure that network traffic between the CIFS server and the client is not compromised.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
svm
name
string
The name of the SVM.
uuid
string
cifs_service
ad_domain
ad_domain
comment
string
default_unix_user
string
enabled
boolean
metric
metric
name
string
netbios
cifs_netbios
security
statistics
statistics
svm
svm
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
