Update a specific FPolicy engine configuration for an SVM
PATCH /protocols/fpolicy/{svm.uuid}/engines/{name}
Introduced In: 9.6
Updates a specific FPolicy engine configuration of an SVM. Modification of an FPolicy engine that is attached to one or more enabled FPolicy policies is not allowed.
Related ONTAP commands
fpolicy policy external-engine modify
Learn more
name |
string |
path |
True |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
port |
integer |
Port number of the FPolicy server application. |
primary_servers |
array[string] |
secondary_servers |
array[string] |
type |
string |
The notification mode determines what ONTAP does after sending notifications to FPolicy servers. The possible values are:
Example request
"port": "9876",
"primary_servers": [
"10.132.145.20",
"10.140.101.109"
"secondary_servers": [
"10.132.145.20",
"10.132.145.21"
"type": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9764922 |
The primary and secondary server has a redundant IP address |
9764942 |
At least one FPolicy policy is using the FPolicy engine |
9764886 |
FPolicy engine is a cluster-level FPolicy engine |
fpolicy_engine
The engine defines how ONTAP makes and manages connections to external FPolicy servers.
port |
integer |
primary_servers |
array[string] |
secondary_servers |
array[string] |
type |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
