Update the NDMP node configuration for a node
PATCH /protocols/ndmp/nodes/{node.uuid}
Introduced In: 9.7
Updates the NDMP node configuration for a specific node.
Related ONTAP commands
system services ndmp modify
Learn more
Name | Type | In | Required | Description |
node.uuid |
string |
path |
True |
Node UUID |
Request Body
Name | Type | Description |
authentication_types |
array[string] |
NDMP authentication types. |
enabled |
boolean |
Is the NDMP service enabled? |
node |
Storage system node |
password |
string |
NDMP password. This can only be set and cannot be read back. |
user |
string |
NDMP user ID |
Example request
"authentication_types": [
"plaintext",
"challenge"
"enabled": 1,
"node": {
"name": "node1",
"password": "string",
"user": "ndmp_user"
Status: 200, Ok
array[string] |
enabled |
boolean |
node |
password |
string |
user |
string |
NDMP user ID |
"plaintext",
"challenge"
"enabled": 1,
"node": {
"name": "node1",
"user": "ndmp_user"
Status: Default
ONTAP Error Response codes
Error code | Description |
68812800 |
The user is required to enable NDMP on a node. |
68812801 |
Node-scoped operations are not allowed in an SVM-scope. |
68812802 |
The UUID is not valid. |
href |
string |
_links
node
Storage system node
name |
string |
uuid |
string |
ndmp_node
array[string] |
enabled |
boolean |
node |
password |
string |
user |
string |
NDMP user ID |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
