Update the NDMP mode
PATCH /protocols/ndmp
Introduced In: 9.7
Updates the NDMP mode.
Related ONTAP commands
system services ndmp node-scope-mode
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
mode |
string |
Indicates whether NDMP is in node-scoped or SVM-scoped mode. |
Example request
"mode": "string"
Status: 200, Ok
mode |
string |
"mode": "string"
Status: Default, Error
href |
string |
_links
cluster_ndmp_properties
mode |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
