Update S3 group configuration for an SVM
PATCH /protocols/s3/services/{svm.uuid}/groups/{id}
Introduced In: 9.8
Updates the S3 group configuration of an SVM.
Important notes
The following fields can be modified for a group:
name- Group name that needs to be modified. -
users- List of users present in the group. -
policies- List of policies to be attached to this group.
Recommended optional properties
comment- Short description about the S3 Group.
Related ONTAP commands
vserver object-store-server group modify
Learn more
id |
integer |
path |
True |
Group identifier that identifies the unique group. |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
comment |
string |
Can contain any additional information about the group being created or modified. |
id |
integer |
Specifies a unique group ID used to identify a particular group. This parameter should not be specified in the POST method. A group ID is automatically generated and it is retrieved using the GET method. Group id is SVM scoped. |
name |
string |
Specifies the name of the group. A group name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
policies |
array[policies] |
Specifies a list of policies that are attached to the group. The wildcard character "*" is a valid value for specifying all policies. |
svm |
users |
array[users] |
Specifies the list of users who belong to the group. |
Example request
"comment": "Admin group",
"id": "5",
"name": "Admin-Group",
"policies": [
"name": "Policy1"
"svm": {
"name": "svm1",
"users": [
"name": "user-1"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405934 |
"Users {users} specified in the user list do not exist for SVM "{svm.name}". Use the "object-store-server user create" command to create a user."; |
92405937 |
"Policies {policies} specified in the policy list do not exist for SVM "{svm.name}". Use the "object-store-server policy create" command to create a policy."; |
href |
string |
_links
policies
name |
string |
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
svm
name |
string |
The name of the SVM. |
uuid |
string |
users
name |
string |
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
s3_group
This is a container for S3 user groups.
comment |
string |
id |
integer |
name |
string |
policies |
array[policies] |
svm |
users |
array[users] |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
