REST API reference
Update the Vscan scanner-pool configuration for an SVM
PATCH /protocols/vscan/{svm.uuid}/scanner-pools/{name}
Introduced In: 9.6
Updates the Vscan scanner-pool configuration of an SVM.
Important notes:
  • Along with servers and privileged-users, the role of a scanner-pool can also be updated with the cluster on which a scanner-pool is allowed.
  • If role is specified and cluster isn't, then role is applied to the local cluster.
  • vserver vscan scanner-pool modify
  • vserver vscan scanner-pool apply-policy
  • vserver vscan scanner-pool privileged-users add
  • vserver vscan scanner-pool privileged-users remove
  • vserver vscan scanner-pool servers remove
  • vserver vscan scanner-pool servers add
name
string
path
True
svm.uuid
string
path
True
Request Body
Name Type Description
cluster
cluster_reference
privileged_users
array[string]
Specifies a list of privileged users. A valid form of privileged user-name is "domain-name\user-name". Privileged user-names are stored and treated as case-insensitive strings. Virus scanners must use one of the registered privileged users for connecting to clustered Data ONTAP for exchanging virus-scanning protocol messages and to access file for scanning, remedying and quarantining operations.
  • example: ["cifs\u1", "cifs\u2"]
  • Introduced in: 9.6
  • x-omitemtpy: true
role
string
Specifies the role of the scanner pool. The possible values are:
  • primary - Always active.
  • secondary - Active only when none of the primary external virus-scanning servers are connected.
  • idle - Always inactive.
servers
array[string]
Specifies a list of IP addresses or FQDN for each Vscan server host names which are allowed to connect to clustered ONTAP.
  • example: ["1.1.1.1", "10.72.204.27", "vmwin204-27.fsct.nb"]
  • x-omitemtpy: true
Example request
  "cluster": {
    "name": "cluster1",
  "privileged_users": [
    "cifs\\u1",
    "cifs\\u2"
  "role": "string",
  "servers": [
    "1.1.1.1",
    "10.72.204.27",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
10027258
The specified cluster_name does not exist
10027256
The specified cluster_uuid does not exist
10027257
The specified cluster_name and cluster_uuid are valid but belong to different clusters
10027248
Scanner-pool updated successfully but failed to apply the specified role
10027107
The list of privileged users or list of servers specified is empty
10027108
The list of privileged users specified contains an invalid entry
10027063
Attempting to modify a scanner-pool on an administrative SVM with a data SVM
string
cluster_reference
name
string
uuid
string
vscan_scanner_pool
Scanner pool is a set of attributes which are used to validate and manage connections between clustered ONTAP and external virus-scanning server, or "Vscan server".
cluster
cluster_reference
privileged_users
array[string]
  • x-omitemtpy: true
role
string
servers
array[string]
  • x-omitemtpy: true
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
