Update a user account
PATCH /security/accounts/{owner.uuid}/{name}
Introduced In: 9.6
Updates a user account. Locks or unlocks a user account and/or updates the role, applications, and/or password for the user account.
Required parameters
name- Account name to be updated. -
owner.uuid- UUID of the SVM housing the user account to be updated.
Optional parameters
applications- Array of one or more tuples (of application and authentication methods). -
role- RBAC role for the user account. -
password- Password for the user account (if the authentication method is opted as password for one or more of applications). -
second_authentication_method- Needed for MFA and only supported for ssh application. Defaults tononeif not supplied. -
comment- Comment for the user account (e.g purpose of this account). -
locked- Set to true/false to lock/unlock the account.
Related ONTAP commands
security login create -
security login modify -
security login password -
security login lock -
security login unlock
owner.uuid  |
string  |
path  |
True  |
Account owner UUID  |
name  |
string  |
path  |
True  |
User account name  |
Request Body
| Name | Type | Description |
applications  |
array[account_application]  |
comment  |
string  |
Optional comment for the user account.  |
locked  |
boolean  |
Locked status of the account.  |
password  |
string  |
Password for the account. The password can contain a mix of lower and upper case alphabetic characters, digits, and special characters.  |
role  |
scope  |
string  |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.  |
Example request
  "applications": [
      "application": "string",
      "authentication_methods": [
        "string"
      "second_authentication_method": "string"
  "comment": "string",
  "password": "string",
  "role": {
    "name": "admin"
  "scope": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1261215  |
The role was not found.  |
1261218  |
The user was not found.  |
1263343  |
Cannot lock user with password not set or non-password authentication method.  |
5636096  |
Cannot perform the operation for this user account since the password is not set.  |
5636097  |
The operation for user account failed since user password is not set.  |
5636100  |
User modification is not supported for service-processor application.  |
5636125  |
The operation not supported on AutoSupport user account which is reserved.  |
5636129  |
The role does not exist.  |
5636154  |
The second-authentication-method parameter is supported for ssh application.  |
5636155  |
The second-authentication-method parameter can be specified only if the authentication-method password or public key nsswitch.  |
5636156  |
Same value cannot be specified for the second-authentication-method and the authentication-method.  |
5636157  |
If the authentication-method is domain, the second-authentication-method cannot be specified.  |
5636159  |
For a given user and application, if the second-authentication-method is specified, only one such login entry is supported.  |
5636164  |
If the value for either the authentication-method second-authentication-method is nsswitch or password, the other parameter must differ.  |
5636174  |
You are not authorized to change the password for other users.  |
7077896  |
Cannot lock the account of the last console admin user.  |
7077906  |
A role with that name has not been defined for the Vserver.  |
7077911  |
The user is not configured to use the password authentication method.  |
7077918  |
The password cannot contain the username.  |
7077919  |
The minimum length for new password does not meet the policy.  |
7077920  |
The new password must have both letters and numbers.  |
7077921  |
The minimum number of special characters required do not meet the policy.  |
7077924  |
The new password must be different than last N passwords.  |
7077925  |
The new password must be different to the old password.  |
7077929  |
7077940  |
The password exceeds maximum supported length.  |
7077941  |
Defined password composition exceeds the maximum password length of 128 characters.  |
7078900  |
An aAdmin password is not set. Set the password by including it in the request.  |
href  |
string  |
_links
account_application
application  |
string  |
Applications  |
authentication_methods  |
array[string]  |
second_authentication_method  |
string  |
An optional additional authentication method for MFA. This only works with SSH as the application. It is ignored for all other applications.  |
owner
Owner name and UUID that uniquely identifies the user account.
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
role
name  |
string  |
Role name  |
account
applications  |
comment  |
string  |
locked  |
boolean  |
password  |
string  |
role  |
scope  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
