REST API reference
Update administrative audit settings for GET requests
PATCH /security/audit
Introduced In: 9.6
Updates administrative audit settings for GET requests. All of the fields are optional. An empty body will make no changes.
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
cli
boolean
Enable auditing of CLI GET Operations. Valid in PATCH
http
boolean
Enable auditing of HTTP GET Operations. Valid in PATCH
ontapi
boolean
Enable auditing of ONTAP API GET operations. Valid in PATCH
  • Introduced in: 9.6
Status: 202, Accepted
cli
boolean
http
boolean
ontapi
boolean
Status: Default, Error
security_audit
cli
boolean
http
boolean
ontapi
boolean
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
