Update the AKV configuration
PATCH /security/azure-key-vaults/{uuid}
Introduced In: 9.8
Updates the AKV configuration.
Required properties
client_secret- New password used to prove the application's identity to the AKV.
Related ONTAP commands
security key-manager external azure modify
uuid |
string |
path |
True |
AKV UUID |
Request Body
| Name | Type | Description |
client_id |
string |
Application client ID of the deployed Azure application with appropriate access to an AKV. |
client_secret |
string |
Password used by the application to prove its identity to AKV. |
key_id |
string |
Key Identifier of AKV key encryption key. |
name |
string |
Name of the deployed AKV that will be used by ONTAP for storing keys.
svm |
tenant_id |
string |
Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV. |
uuid |
string |
A unique identifier for the Azure Key Vault (AKV). |
Example request
"client_id": "aaaaaaaa-bbbb-aaaa-bbbb-aaaaaaaaaaaa",
"client_secret": "abcdef",
"key_id": "https://keyvault1.vault.azure.net/keys/key1/a8e619fd8f234db3b0b95c59540e2a74",
"name": "https://kmip-akv-keyvault.vault.azure.net/",
"svm": {
"name": "svm1",
"tenant_id": "zzzzzzzz-yyyy-zzzz-yyyy-zzzzzzzzzzzz",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537503 |
Passwords do not match. |
65537504 |
Internal error. Failed to store configuration in internal database. |
65537511 |
AKV is not configured for the given SVM. |
65537517 |
The field "new_client_secret" must be specified. |
href |
string |
_links
state
Indicates whether the AKV key protection is available cluster wide.
cluster_state |
boolean |
Set to true when AKV key protection is available on all nodes of the cluster. |
code |
integer |
Code corresponding to the status message. Returns a 0 if AKV key protection is available in all nodes of the cluster. |
message |
string |
Error message set when cluster availability is false. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
azure_key_vault
client_id |
string |
client_secret |
string |
key_id |
string |
name |
string |
svm |
tenant_id |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
