Update key managers
PATCH /security/key-managers/{uuid}
Introduced In: 9.6
Updates a key manager.
Required properties
onboard.existing_passphrase- Cluster-wide passphrase. Required only when synchronizing the passphrase of the Onboard Key Manager. -
synchronize- Synchronizes missing Onboard Key Manager keys on any node in the cluster. Required only when synchronizing the Onboard Key Manager keys in a local cluster.
Related ONTAP commands
security key-manager external modify -
security key-manager onboard sync -
security key-manager onboard update-passphrase
uuid  |
string  |
path  |
True  |
Key manager UUID  |
Request Body
| Name | Type | Description |
external  |
Configures external key management  |
is_default_data_at_rest_encryption_disabled  |
boolean  |
Indicates whether default data-at-rest encryption is disabled in the cluster.  |
onboard  |
Configures onboard key management. After configuring onboard key management, save the encrypted configuration data in a safe location so that you can use it if you need to perform a manual recovery operation.  |
svm  |
uuid  |
string  |
Example request
  "external": {
    "client_certificate": {
      "name": "cert1",
    "server_ca_certificates": [
        "name": "cert1",
    "servers": [
        "secondary_key_servers": [
          "string"
        "timeout": "60",
        "username": "admin"
  "onboard": {
    "existing_passphrase": "The cluster password of length 32-256 ASCII characters.",
    "key_backup": "'--------------------------BEGIN BACKUP-------------------------- TmV0QXBwIEtleSBCbG9iAAEAAAAEAAAAcAEAAAAAAAAxBFWWAAAAACEAAAAAAAAA QAAAAAAAAABzDyyVAAAAALI5Jsjvy6gUxnT78KoDKXHYb6sSeraM00quOULY6BeV n6dMFxuErCD1lbERaOQZSuaYy1p8oQHtTEfGMLZM4TYiAAAAAAAAACgAAAAAAAAA 3WTh7gAAAAAAAAAAAAAAAAIAAAAAAAgAZJEIWvdeHr5RCAvHGclo+wAAAAAAAAAA IgAAAAAAAAAoAAAAAAAAAEOTcR0AAAAAAAAAAAAAAAACAAAAAAAJAGr3tJA/LRzU QRHwv+1aWvAAAAAAAAAAACQAAAAAAAAAgAAAAAAAAADV1Vd/AAAAAMFM9Q229Bhp mDaTSdqku5DCd8wG+fOZSr4bx4JT5WHvV/r5gJnXDQQAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABOZXRBcHAgS2V5IEJsb2IA AQAAAAMAAAAYAQAAAAAAALgePkcAAAAAIgAAAAAAAAAoAAAAAAAAAEOTcR0AAAAA AAAAAAAAAAACAAAAAAAJAGr3tJA/LRzUQRHwv+1aWvAAAAAAAAAAACIAAAAAAAAA KAAAAAAAAACIlCHZAAAAAAAAAAAAAAAAAgAAAAAAAQCafcabsxRXMM7gxhLRrzxh AAAAAAAAAAAkAAAAAAAAAIAAAAAAAAAA2JjQBQAAAACt4IqXcNpVggahl0axLsN4 yQjnNVKWY7mANB29O42hI7b70DTGCTaVAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAE5ldEFwcCBLZXkgQmxvYgABAAAAAwAAABgBAAAAAAAA 7sbaoQAAAAAiAAAAAAAAACgAAAAAAAAAQ5NxHQAAAAAAAAAAAAAAAAIAAAAAAAkA ave0kD8tHNRBEfC/7Vpa8AAAAAAAAAAAIgAAAAAAAAAoAAAAAAAAALOHfWkAAAAA AAAAAAAAAAACAAAAAAABAMoI9UxrHOGthQm/CB+EHdAAAAAAAAAAACQAAAAAAAAA gAAAAAAAAACnMmUtAAAAAGVk8AtPzENFgsGdsFvnmucmYrlQCsFew0HDSFKaZqK6 W8IEVzBAhPoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA ---------------------------END BACKUP---------------------------'",
    "passphrase": "The cluster password of length 32-256 ASCII characters."
  "svm": {
    "name": "svm1",
  "uuid": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536139  |
The existing passphrase value provided does not match the configured passphrase.  |
65536150  |
The new passphrase is same as old passphrase.  |
65536404  |
The passphrase does not match the accepted length.  |
65536406  |
The change of passphrase failed.  |
65536407  |
The passphrase update failed on some nodes.  |
65536408  |
65536802  |
The passphrase does not match the accepted length in common criteria mode.  |
65536821  |
The certificate is not installed.  |
65536822  |
Multitenant key management is not supported in the current cluster version.  |
65536828  |
External key management is not enabled for the SVM.  |
65536850  |
New client certificate public or private keys are different from the existing client certificate.  |
65536852  |
Failed to query supported KMIP protocol versions.  |
65536917  |
Updating an onboard passhrase requires both new and existing cluster passphrase.  |
65537242  |
The Onboard Key Manager existing_passphrase must be provided when performing a PATCH/synchronize operation.  |
65537243  |
The Onboard Key Manager passphrase must not be provided when performing a PATCH/synchronize operation.  |
66060338  |
Failed to establish secure connection for a key management server due to incorrect server_ca certificates.  |
66060339  |
Failed to establish secure connection for a key management server due to incorrect client certificates.  |
66060340  |
Failed to establish secure connection for a key management server due to Cryptsoft error.  |
href  |
string  |
_links
client_certificate
Client certificate
name  |
string  |
Certificate name  |
uuid  |
string  |
Certificate UUID  |
name  |
string  |
Certificate name  |
uuid  |
string  |
Certificate UUID  |
self_link
key_server_readcreate
secondary_key_servers  |
array[string]  |
A list of the secondary key servers associated with the primary key server.  |
timeout  |
integer  |
I/O timeout in seconds for communicating with the key server.  |
username  |
string  |
Username credentials for connecting with the key server.  |
external
client_certificate  |
Client certificate  |
server_ca_certificates  |
array[server_ca_certificates]  |
The UUIDs of the server CA certificates already installed in the cluster or SVM. The array of certificates are common for all the keyservers per SVM.  |
servers  |
array[key_server_readcreate]  |
The set of external key servers.  |
onboard
enabled  |
boolean  |
Is the onboard key manager enabled?  |
existing_passphrase  |
string  |
The cluster-wide passphrase. This is not audited.  |
key_backup  |
string  |
Backup of the onboard key manager's key hierarchy. It is required to save this backup after configuring the onboard key manager to help in the recovery of the cluster in case of catastrophic failures.  |
passphrase  |
string  |
synchronize  |
boolean  |
Synchronizes missing onboard keys on any node in the cluster. If a node is added to a cluster that has onboard key management configured, the synchronize operation needs to be performed in a PATCH operation. In a MetroCluster configuration, if onboard key management is enabled on one site, then the synchronize operation needs to be run as a POST operation on the remote site providing the same passphrase.  |
status
Optional status information on the current state of the key manager indicating if it is fully setup or requires more action.
code  |
integer  |
Code corresponding to the status message. Returns 0 if the setup is complete. This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the   |
message  |
string  |
Current state of the key manager indicating any additional steps to perform to finish the setup. This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the   |
svm
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
volume_encryption
Indicates whether volume encryption is supported in the cluster.
code  |
integer  |
Code corresponding to the status message. Returns a 0 if volume encryption is supported in all nodes of the cluster.  |
message  |
string  |
Reason for not supporting volume encryption.  |
supported  |
boolean  |
Set to true when volume encryption support is available on all nodes of the cluster.  |
security_key_manager
external  |
boolean  |
onboard  |
svm  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
