Update a primary key server
PATCH /security/key-managers/{uuid}/key-servers/{server}
Introduced In: 9.6
Updates a key server.
Related ONTAP commands
security key-manager external modify-server
uuid  |
string  |
path  |
True  |
External key manager UUID  |
server  |
string  |
path  |
True  |
Key server configured in the external key manager.  |
Request Body
| Name | Type | Description |
password  |
string  |
Password credentials for connecting with the key server. This is not audited.  |
secondary_key_servers  |
array[string]  |
A list of the secondary key servers associated with the primary key server.  |
timeout  |
integer  |
I/O timeout in seconds for communicating with the key server.  |
username  |
string  |
KMIP username credentials for connecting with the key server.  |
Example request
  "password": "password",
  "secondary_key_servers": [
    "string"
  "timeout": "60",
  "username": "username"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536822  |
Multitenant key management is not supported in the current cluster version.  |
65536824  |
Multitenant key management is not supported in MetroCluster configurations.  |
65536828  |
External key management is not enabled for the SVM.  |
65536843  |
The key management server is not configured for the SVM.  |
65536845  |
Missing username.  |
65536846  |
Missing password.  |
href  |
string  |
_links
records
password  |
string  |
array[string]  |
timeout  |
integer  |
username  |
string  |
key_server
password  |
string  |
array[string]  |
timeout  |
integer  |
username  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
