Update the software FIPS mode or enable conversion of non-encrypted metadata volumes non-NAE aggregates
PATCH /security
Introduced In: 9.8
Updates the software FIPS mode or enables conversion of non-encrypted metadata volumes to encrypted metadata volumes and non-NAE aggregates to NAE aggregates.
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
fips |
Cluster-wide Federal Information Processing Standards (FIPS) mode information. |
software_data_encryption |
Cluster-wide software data encryption related information. |
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
52428830 |
Cannot enable FIPS-compliant mode because the configured minimum security strength for certificates is not compatible. |
52559974 |
Cannot enable FIPS-compliant mode because a certificate that is not FIPS-compliant is in use. |
196608081 |
Cannot start software encryption conversion while there are data volumes in the cluster. |
196608082 |
The operation is not valid when the MetroCluster is in switchover mode. |
href |
string |
_links
fips
enabled |
boolean |
Indicates whether or not the software FIPS mode is enabled on the cluster. Our FIPS compliance involves configuring the use of only approved algorithms in applicable contexts (for example TLS), as well as the use of formally validated cryptographic module software implementations, where applicable. The US government documents concerning FIPS 140-2 outline the relevant security policies in detail. |
onboard_key_manager_configurable_status
Indicates whether the Onboard Key Manager can be configured in the cluster.
code |
integer |
Code corresponding to the status message. Returns a 0 if the Onboard Key Manager can be configured in the cluster. |
message |
string |
Reason that Onboard Key Manager cannot be configured in the cluster. |
supported |
boolean |
Set to true if the Onboard Key Manager can be configured in the cluster. |
conversion_enabled |
boolean |
Indicates whether or not software encryption conversion is enabled on the cluster. A PATCH request initiates the conversion of all non-encrypted metadata volumes in the cluster to encrypted metadata volumes and all non-NAE aggregates to NAE aggregates. For the PATCH request to start, the cluster must have either an Onboard or an external key manager set up and the aggregates should either be empty or have only metadata volumes. No data volumes should be present in any of the aggregates in the cluster. For MetroCluster configurations, a PATCH request enables conversion on all the aggregates and metadata volumes of both local and remote clusters and is not allowed when the MetroCluster is in switchover state. |
security_config
fips |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
