Update disk ownership, change authentication keys, or sanitize disks
PATCH /storage/disks
Introduced In: 9.7
Updates disk ownership or authentication keys.
Related ONTAP commands
storage disk assign -
storage encryption disk modify -data-key-id -
security key-manager key query -key-type NSE-AK
Learn more
name |
string |
query |
False |
Disk name |
encryption_operation |
string |
query |
False |
Name of the operation to apply to encrypting disks.
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
aggregates |
array[aggregates] |
List of aggregates sharing this disk |
bay |
integer |
Disk shelf bay |
class |
string |
Disk class |
container_type |
string |
Type of overlying disk container |
drawer |
string |
Encryption operation to apply to the drives. Possible values are:
fips_certified |
boolean |
firmware_version |
string |
key_id |
model |
string |
name |
string |
Cluster-wide disk name |
pool |
string |
Pool to which disk is assigned |
protection_mode |
string |
Mode of drive data protection and FIPS compliance. Possible values are:
rated_life_used_percent |
integer |
Percentage of rated life used |
rpm |
integer |
Revolutions per minute |
self_encrypting |
boolean |
serial_number |
string |
state |
string |
State |
type |
string |
Disk interface type |
uid |
string |
The unique identifier for a disk |
usable_size |
integer |
vendor |
string |
Example request
"aggregates": [
"name": "aggr1",
"bay": "1",
"class": "solid_state",
"container_type": "spare",
"encryption_operation": "string",
"firmware_version": "NA51",
"key_id": {
"data": "string",
"fips": "string"
"model": "X421_HCOBE450A10",
"name": "1.0.1",
"pool": "pool0",
"protection_mode": "string",
"rated_life_used_percent": "10",
"rpm": "15000",
"serial_number": "KHG2VX8R",
"state": "present",
"type": "ssd",
"uid": "002538E5:71B00B2F:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000",
"usable_size": "959934889984",
"vendor": "NETAPP"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
721066 |
Node is outside the list of controllers for disk. |
1441795 |
Setting the data key ID to the manufacture secure ID is not allowed when in FIPS-compliance mode. |
14155777 |
The operation failed on one or more disks. |
14155778 |
No self-encrypting disks were specified. |
14155779 |
Status from a node shows that a conflicting operation has occurred. Some disk controls might have changed. |
14155780 |
Could not retrieve the required key ID from the key manager. |
14155786 |
Changes to encryption controls are not allowed with drive assignment. |
href |
string |
_links
aggregates
Aggregate
name |
string |
uuid |
string |
dr_node
name |
string |
uuid |
string |
drawer
id |
integer |
slot |
integer |
home_node
name |
string |
uuid |
string |
key_id
data |
string |
Key ID of the data authentication key |
fips |
string |
Key ID of the FIPS authentication key |
node
name |
string |
uuid |
string |
shelf
uid |
string |
disk
aggregates |
array[aggregates] |
bay |
integer |
Disk shelf bay |
class |
string |
Disk class |
container_type |
string |
drawer |
string |
fips_certified |
boolean |
firmware_version |
string |
key_id |
model |
string |
name |
string |
pool |
string |
protection_mode |
string |
integer |
rpm |
integer |
self_encrypting |
boolean |
serial_number |
string |
state |
string |
State |
type |
string |
uid |
string |
usable_size |
integer |
vendor |
string |
