REST API reference
Update SnapLock audit logs
PATCH /storage/snaplock/audit-logs/{svm.uuid}
Introduced In: 9.7
Updates one of the following:
  • the audit log volume,
  • the attributes of the audit log volume present, or
  • archive the current audit log files
  • snaplock log modify
svm.uuid
string
path
True
SVM UUID
return_timeout
integer
query
False
  • Default value: 1
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
log_archive
log_archive
log_volume
snaplock_log_volume
Example request
  "log_archive": {
    "base_name": "string",
    "expiry_time": "2058-06-04T19:00:00Z",
    "path": "/snaplock_log/system_logs/20180822_005947_GMT-present",
    "size": "20000"
  "log_volume": {
    "max_log_size": "20971520",
    "retention_period": "P30M",
    "volume": {
      "name": "volume1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response codes
Error code Description
14090344
If log_volume is specified, then log_archive must not be specified
14090345
If log_archive.base_name is specified, then log_archive.archive must also be specified
14090346
Internal Error. Wait a few minutes, then try the command again
string
log_archive
archive
boolean
Archive the specified SnapLock log file for the given base_name, and create a new log file. If base_name is not mentioned, archive all log files.
base_name
string
Base name of log file
expiry_time
string
Expiry time of the log file in date-time format. Value '9999-12-31T00:00:00Z' indicates infinite expiry time.
path
string
Absolute path of the log file in the volume
size
integer
Size of the log file in bytes
snaplock_log_file
archive
boolean
base_name
string
expiry_time
string
path
string
size
integer
volume
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
snaplock_log_volume
max_log_size
integer
Maximum size of log file in bytes
retention_period
string
Specifies the default log record retention period. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, minutes and seconds. A period specified for years, months and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively. For example "P10Y" represents a duration of 10 years. A duration in hours, minutes and seconds is represented by "PTH", "PTM", and "PTS" respectively. The period string must contain only a single time element i.e. either years, months, days, hours, minutes or seconds. A duration which combines different periods is not supported, example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the retention period field also accepts the string "infinite".
volume
volume
svm
name
string
The name of the SVM.
uuid
string
snaplock_log
log_archive
log_archive
log_volume
snaplock_log_volume
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
