Update an EMS configuration
PATCH /support/ems
Introduced In: 9.6
Updates the EMS configuration.
Related ONTAP commands
event config modify
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
mail_from  |
string  |
Mail from  |
mail_server  |
string  |
Mail server (SMTP)  |
proxy_password  |
string  |
Password for HTTP/HTTPS proxy  |
proxy_url  |
string  |
HTTP/HTTPS proxy URL  |
proxy_user  |
string  |
User name for HTTP/HTTPS proxy  |
pubsub_enabled  |
boolean  |
Is Publish/Subscribe Messaging Enabled?  |
Example request
  "mail_from": "administrator@mycompany.com",
  "mail_server": "mail@mycompany.com",
  "proxy_password": "password",
  "proxy_url": "https://proxyserver.mycompany.com",
  "proxy_user": "proxy_user",
  "pubsub_enabled": 1
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983123  |
The validation of the mail server provided failed  |
983136  |
The proxy URL cannot contain a username or password  |
983137  |
The proxy URLprovided is invalid  |
983139  |
The IPv6 proxy URL provided is invalid  |
983140  |
The proxy URL provided contains an invalid scheme. Supported schemes are 'http' or 'https'  |
href  |
string  |
_links
ems_config
mail_from  |
string  |
Mail from  |
mail_server  |
string  |
proxy_password  |
string  |
proxy_url  |
string  |
proxy_user  |
string  |
pubsub_enabled  |
boolean  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
