REST API reference
Start MetroCluster diagnostics or set up a periodic diagnostic schedule
POST /cluster/metrocluster/diagnostics
Introduced In: 9.8
Start a MetroCluster diagnostic operation or set up a schedule for the diagnostics to be run periodically.
schedule
integer
query
False
Shows the minutes of every hour when a job runs. Setting this parameter schedules the periodic job to be run to perform MetroCluster diagnostic.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
2427132
MetroCluster is not configured on this cluster.
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
