Create a peering relationship
POST /cluster/peers
Introduced In: 9.6
Creates a peering relationship and, optionally, the IP interfaces it will use. There are two methods used to create a peering relationship:
Provide a remote IP address - Used when creating a new cluster peer relationship with a specific remote cluster. This requires at least one remote intercluster IP address from the remote cluster.
Do not provide a remote IP address - Used when the remote IP address is not provided and when the storage system is ready to accept peering requests from foreign clusters.
Required properties
remote.ip_addresses- Addresses of the remote peers. The local peer must be able to reach and connect to these addresses for the request to succeed in creating a peer. Only required when creating a peering relationship by providing a remote IP address. -
Either set
generate_passphraseto "true" or provide a passphrase in the body of the request. Only one of these options is required.
Recommended optional properties
name- Name of the peering relationship or name of the remote peer. -
passphrase- User generated passphrase for use in authentication. -
generate_passphrase(true/false) - When "true", ONTAP automatically generates a passphrase to authenticate cluster peers. -
ipspace- IPspace of the local intercluster LIFs. Assumes Default IPspace if not provided. -
initial_allowed_svms- Local SVMs allowed to peer with the peer cluster's SVMs. Can be modified until the remote cluster accepts this cluster peering relationship. -
local_network- Fields to create a local intercluster LIF. -
expiry_time- Duration in ISO 8601 format for which the user-supplied or auto-generated passphrase is valid. Expiration time must not be greater than seven days into the future. ISO 8601 duration format is "PnDTnHnMnS" or "PnW" where n is a positive integer. The "nD", "nH", "nM" and "nS" fields can be dropped if zero. "P" must always be present and "T" must be present if there are any hours, minutes, or seconds fields. -
encryption_proposed(none/tls-psk) - Encryption mechanism of the communication channel between the two peers. -
peer_applications- SVM peering applications (SnapMirror, FlexCache or both) for which the SVM peering relationship is set up.
Additional information
As with creating a cluster peer through the CLI, the combinations of options must be valid in order for the create operation to succeed. The following list shows the combinations that will succeed and those that will fail:
A passphrase only (fail)
A peer IP address (fail)
A passphrase with an expiration time > 7 days into the future (fail)
A peer IP address and a passphrase (OK)
generate_passphrase=true (OK)
Any proposed encryption protocol (OK)
An IPspace name or UUID (OK)
A passphrase, peer IP address, and any proposed encryption protocol (OK)
A non empty list of initial allowed SVM peer names or UUIDs. (OK)
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
_links |
authentication |
encryption |
initial_allowed_svms |
array[initial_allowed_svms] |
The local SVMs allowed to peer with the peer cluster's SVMs. This list can be modified until the remote cluster accepts this cluster peering relationship. |
ipspace |
The IPspace of the local intercluster LIFs. |
local_network |
Cluster peering requires an intercluster LIF on each local node. These can be optionally created by specifying a list of IP addresses corresponding to each node. |
name |
string |
Optional name for the cluster peer relationship. By default, it is the name of the remote cluster. |
peer_applications |
array[string] |
Peering applications against which allowed SVMs are configured. |
remote |
status |
uuid |
string |
UUID of the cluster peer relationship. For anonymous cluster peer offers, the UUID will change when the remote cluster accepts the relationship. |
Example request
"authentication": {
"expiry_time": "P1DT2H3M4S or '2017-01-25T11:20:13Z'",
"in_use": "string",
"passphrase": "string",
"state": "string"
"encryption": {
"proposed": "string",
"state": "string"
"initial_allowed_svms": [
"name": "svm1",
"ipspace": {
"name": "exchange",
"local_network": {
"broadcast_domain": "bd1",
"gateway": "10.1.1.1",
"interfaces": [
"ip_address": "10.10.10.7"
"netmask": "255.255.0.0"
"name": "cluster2",
"peer_applications": [
"snapmirror",
"flexcache"
"remote": {
"ip_addresses": [
"10.10.10.7"
"name": "cluster2",
"serial_number": "4048820-60-9"
"status": {
"state": "available",
"update_time": "2017-01-25T11:20:13Z"
Status: 201, Created
authentication |
ip_address |
string |
IPv4 or IPv6 address |
name |
string |
Optional name for the cluster peer relationship. By default, it is the name of the remote cluster, or a temporary name might be autogenerated for anonymous cluster peer offers. |
"authentication": {
"expiry_time": "2017-01-25T11:20:13Z",
"ip_address": "10.10.10.7",
"name": "cluster2"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1966366 |
The system SVM of the cluster IPspace hosts cluster LIFs only. |
4653365 |
IPspaces are unavailable with cluster peering: {ipspace}. |
4656069 |
Specifying a passphrase without remote IP addresses is not supported. |
4656070 |
The encryption protocol is meaningful only with authenticated cluster peer relationships. |
4656071 |
Cannot peer with a cluster bearing the same name as the local cluster. |
4656072 |
The name must conform to the same rules as a cluster name. |
4656074 |
Cannot check whether all nodes of this cluster support encryption. |
4656075 |
Cannot specify encryption: this operation requires an ECV of 9.6.0 or later. |
4656077 |
Specify either remote IP addresses or generate_passphrase. |
4656079 |
No cluster nodes were found. Check your cluster configuration. |
4656081 |
Creating an intercluster LIF requires a list of local IP addresses. |
4656085 |
Cannot create an intercluster LIF with an empty list of local IP addresses. |
4656086 |
Creating an intercluster LIF requires a broadcast domain that is in use within the IPspace. |
4656087 |
The number of local intercluster IP addresses must be less than or equal to the number of available nodes. |
4656088 |
Found no ports matching the IPspace and the broadcast domain. |
4656089 |
Found no matching entry for IPspace. |
4656090 |
The given IPspace differs from the IPspace entry found. |
4656091 |
Creating an intercluster LIF requires a subnet mask or a subnet mask length. |
4656096 |
Creating an intercluster LIF requires an IPv4 or IPv6 address of the default router. |
href |
string |
_links
authentication
expiry_time |
string |
The time when the passphrase will expire, in ISO 8601 duration format or date and time format. The default is 1 hour. |
generate_passphrase |
boolean |
Auto generate a passphrase when true. |
in_use |
string |
passphrase |
string |
A password to authenticate the cluster peer relationship. |
state |
string |
encryption
proposed |
string |
state |
string |
name |
string |
The name of the SVM. |
uuid |
string |
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
interfaces
ip_address |
string |
local_network
broadcast_domain |
string |
Broadcast domain that is in use within the IPspace. |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
interfaces |
array[interfaces] |
netmask |
string |
IPv4 mask or netmask length. |
remote
ip_addresses |
array[string] |
The IPv4 addresses, IPv6 addresses, or hostnames of the peers. |
name |
string |
The name of the remote cluster. |
serial_number |
string |
The serial number of the remote cluster. |
status
state |
string |
update_time |
string |
The last time the state was updated. |
version
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes.
full |
string |
The full cluster version string. |
generation |
integer |
The generation portion of the version. |
major |
integer |
The major portion of the version. |
minor |
integer |
The minor portion of the version. |
cluster_peer
_links |
authentication |
encryption |
ipspace |
local_network |
name |
string |
peer_applications |
array[string] |
remote |
status |
uuid |
string |
authentication
expiry_time |
string |
The date and time the passphrase will expire. The default expiry time is one hour. |
passphrase |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
