REST API reference
Download a software or firmware package
POST /cluster/software/download
Introduced In: 9.6
Downloads a software package from the server.
Required properties
  • url - URL location of the software package
  • username - Username of HTTPS/FTP server
  • password - Password of HTTPS/FTP server
  • cluster image package get
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
password
string
Password for download
url
string
HTTP or FTP URL of the package through a server
username
string
Username for download
Example request
  "password": "admin_password",
  "url": "http://server/package",
  "username": "admin"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default, Error
software_package_download
password
string
url
string
username
string
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
