Upload a software or firmware package located on the local file system
POST /cluster/software/upload
Introduced In: 9.8
Uploads a software package file located on the local filesystem.
Related ONTAP commands
cluster image package get
Learn more
file  |
file  |
formData  |
False  |
Info specification  |
return_records  |
boolean  |
query  |
False  |
return_timeout  |
integer  |
query  |
False  |
Status: 202, Accepted
| Name | Type | Description |
job  |
  "job": {
    "uuid": "string"
Status: Default, Error
href  |
string  |
_links
job_link
uuid  |
string  |
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
