Create DNS domain and server configurations
POST /name-services/dns
Introduced In: 9.6
Creates DNS domain and server configurations for an SVM.
Important notes
Each SVM can have only one DNS configuration.
The domain name and the servers fields cannot be empty.
IPv6 must be enabled if IPv6 family addresses are specified in the
serversfield. -
Configuring more than one DNS server is recommended to avoid a single point of failure.
The DNS server specified using the
serversfield is validated during this operation.
The validation fails in the following scenarios:
The server is not a DNS server.
The server does not exist.
The server is unreachable.
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
domains |
array[string] |
A list of DNS domains. Domain names have the following requirements:
servers |
array[string] |
The list of IP addresses of the DNS servers. Addresses can be either IPv4 or IPv6 addresses. |
svm |
Example request
"domains": [
"example.com",
"example2.example3.com"
"servers": [
"10.224.65.20",
"2001:db08:a0b:12f0::1"
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of DNS domain records |
records |
array[dns] |
"records": [
"domains": [
"example.com",
"servers": [
"10.224.65.20",
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621706 |
The specified SVM UUID is incorrect for the specified SVM name |
8847360 |
Only admin or data SVMs allowed |
8847361 |
Exceeded the maximum number of domains allowed. Maximum of six domains only |
8847362 |
Exceeded the maximum number of name servers allowed. Maximum of three name servers only |
8847392 |
Domain name cannot be an IP address |
8847393 |
Top level domain name is invalid |
8847399 |
One or more of the specified DNS servers do not exist or cannot be reached |
8847394 |
FQDN name violated the limitations |
9240587 |
FQDN name cannot be empty |
9240588 |
FQDN name is too long. Maximum supported length: 255 characters |
9240590 |
FQDN name is reserved. Following names are reserved: "all", "local" and "localhost" |
9240607 |
One of the FQDN labels is too long. Maximum supported length: 63 characters |
13434916 |
The SVM is in the process of being created. Wait a few minutes, and then try the command again. |
23724130 |
Cannot use an IPv6 name server address because there are no IPv6 LIFs |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
dns
domains |
array[string] |
servers |
array[string] |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
