Create an HTTP proxy configuration for an SVM or cluster IPspace
POST /network/http-proxy
Introduced In: 9.7
Creates an HTTP proxy configuration for an SVM or a Cluster IPspace. Important notes:
IPv6 must be enabled if IPv6 family addresses are specified in the "server" field.
The server and the port combination specified using the "server" and "port" fields is validated during this operation. The validation will fail in the following scenarios:
The HTTP proxy service is not configured on the server.
The HTTP proxy service is not running on the specified port.
The server is unreachable.
Required properties
SVM-scoped HTTP proxy
svm.uuidorsvm.name- Existing SVM in which to create the HTTP proxy.
Cluster-scoped HTTP proxy
ipspace.uuidoripspace.name- Exisitng Cluster IPspace in which to create the HTTP proxy.
server- HTTP proxy server FQDN or IP address. -
port- HTTP proxy server port.
Related ONTAP commands
vserver http-proxy create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input. |
port |
integer |
The port number on which the HTTP proxy service is configured on the proxy server. |
scope |
string |
Set to “svm” for proxy owned by an SVM. Otherwise, set to "cluster". |
server |
string |
The fully qualified domain name (FQDN) or IP address of the proxy server. |
svm |
uuid |
string |
The UUID that uniquely identifies the HTTP proxy. |
Example request
"ipspace": {
"name": "exchange",
"port": "3128",
"scope": "string",
"server": "string",
"svm": {
"name": "svm1",
"uuid": "string"
Status: 201, Created
num_records |
integer |
Number of HTTP proxy records |
records |
array[network_http_proxy] |
"records": [
"ipspace": {
"name": "exchange",
"port": "3128",
"scope": "string",
"server": "string",
"svm": {
"name": "svm1",
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
26214473 |
HTTP proxy configuration is not valid. |
26214476 |
The "IPspace" parameter should not be specified in the SVM context. |
26214477 |
The specified IPspace does not exist. |
23724130 |
Cannot use an IPv6 name server address because there are no IPv6 interfaces. |
href |
string |
_links
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
name |
string |
The name of the SVM. |
uuid |
string |
network_http_proxy
ipspace |
port |
integer |
scope |
string |
server |
string |
svm |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
