Create an FPolicy engine configuration for an SVM
POST /protocols/fpolicy/{svm.uuid}/engines
Introduced In: 9.6
Creates an FPolicy engine configuration for a specified SVM. FPolicy engine creation is allowed only on data SVMs.
Required properties
svm.uuid- Existing SVM in which to create the FPolicy engine. -
name- Name of external engine. -
port- Port number of the FPolicy server application. -
primary_servers- List of primary FPolicy servers to which the node will send notifications.
Recommended optional properties
secondary_servers- It is recommended to configure secondary FPolicy server to which the node will send notifications when the primary server is down.
Default property values
type- synchronous
Related ONTAP commands
fpolicy policy external-engine create
Learn more
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
name |
string |
Specifies the name to assign to the external server configuration. |
port |
integer |
Port number of the FPolicy server application. |
primary_servers |
array[string] |
secondary_servers |
array[string] |
type |
string |
The notification mode determines what ONTAP does after sending notifications to FPolicy servers. The possible values are:
Example request
"name": "fp_ex_eng",
"port": "9876",
"primary_servers": [
"10.132.145.20",
"10.140.101.109"
"secondary_servers": [
"10.132.145.20",
"10.132.145.21"
"type": "string"
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[fpolicy_engine] |
"records": [
"port": "9876",
"10.132.145.20",
"10.140.101.109"
"10.132.145.20",
"10.132.145.21"
"type": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9764885 |
The primary secondary server has a redundant IP address |
9764953 |
The name of the FPolicy engine is "native" which is reserved by the system |
fpolicy_engine
The engine defines how ONTAP makes and manages connections to external FPolicy servers.
name |
string |
port |
integer |
primary_servers |
array[string] |
secondary_servers |
array[string] |
type |
string |
href |
string |
_links
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
