Create an export policy rule client
POST /protocols/nfs/export-policies/{policy.id}/rules/{index}/clients
Introduced In: 9.6
Creates an export policy rule client
Required properties
policy.id- Existing export policy that contains export policy rules for the client being added. -
index- Existing export policy rule for which to create an export client. -
match- Base name for the export policy client.
Related ONTAP commands
vserver export-policy rule add-clientmatches
Learn more
policy.id  |
integer  |
path  |
True  |
Export Policy ID  |
index  |
integer  |
path  |
True  |
Export Rule Index  |
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
match  |
string  |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
Example request
  "match": "0.0.0.0/0"
Status: 201, Created
num_records  |
integer  |
Number of export rule client records  |
records  |
array[export_client]  |
  "records": [
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1703954  |
Export policy does not exist  |
1704036  |
Invalid clientmatch: missing domain name  |
1704037  |
Invalid clientmatch: missing network name  |
1704038  |
Invalid clientmatch: missing netgroup name  |
1704039  |
Invalid clientmatch  |
1704040  |
Invalid clientmatch: address bytes masked out by netmask are non-zero  |
1704041  |
Invalid clientmatch: address bytes masked to zero by netmask  |
1704042  |
Invalid clientmatch: too many bits in netmask  |
1704043  |
Invalid clientmatch: invalid netmask  |
1704044  |
Invalid clientmatch: invalid characters in host name  |
1704045  |
Invalid clientmatch: invalid characters in domain name  |
1704050  |
Invalid clientmatch: the clientmatch list contains a duplicate string. Duplicate strings in a clientmatch list are not supported  |
1704051  |
Warning: Not adding any new strings to the clientmatch field for ruleindex. All of the match strings are already in the clientmatch list  |
1704064  |
Clientmatch host name too long  |
1704065  |
Clientmatch domain name too long  |
export_client
match  |
string  |
href  |
string  |
_links
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
