Create an export policy rule
POST /protocols/nfs/export-policies/{policy.id}/rules
Introduced In: 9.6
Creates an export policy rule.
Required properties
policy.id- Existing export policy for which to create an export rule. -
clients.match- List of clients (hostnames, ipaddresses, netgroups, domains) to which the export rule applies. -
ro_rule- Used to specify the security type for read-only access to volumes that use the export rule. -
rw_rule- Used to specify the security type for read-write access to volumes that use the export rule.
Default property values
If not specified in POST, the following default property values are assigned:
protocols- any -
anonymous_user- none -
superuser- any
Related ONTAP commands
vserver export-policy rule create
Learn more
policy.id |
integer |
path |
True |
Export Policy ID |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
anonymous_user |
string |
User ID To Which Anonymous Users Are Mapped. |
clients |
array[export_client] |
Array of client matches |
index |
integer |
Index of the rule within the export policy. |
protocols |
array[string] |
ro_rule |
array[string] |
Authentication flavors that the read-only access rule governs |
rw_rule |
array[string] |
Authentication flavors that the read/write access rule governs |
superuser |
array[string] |
Authentication flavors that the superuser security type governs |
Example request
"anonymous_user": "string",
"clients": [
"match": "0.0.0.0/0"
"index": 0,
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
Status: 201, Created
num_records |
integer |
Number of Export Rule records |
records |
array[export_rule] |
"records": [
"clients": [
"index": 0,
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1703954 |
Export policy does not exist |
1704036 |
Invalid clientmatch: missing domain name |
1704037 |
Invalid clientmatch: missing network name |
1704038 |
Invalid clientmatch: missing netgroup name |
1704039 |
Invalid clientmatch |
1704040 |
Invalid clientmatch: address bytes masked out by netmask are non-zero |
1704041 |
Invalid clientmatch: address bytes masked to zero by netmask |
1704042 |
Invalid clientmatch: too many bits in netmask |
1704043 |
Invalid clientmatch: invalid netmask |
1704044 |
Invalid clientmatch: invalid characters in host name |
1704045 |
Invalid clientmatch: invalid characters in domain name |
1704050 |
Invalid clientmatch: clientmatch list contains a duplicate string. Duplicate strings in a clientmatch list are not supported |
1704051 |
Warning: Not adding any new strings to the clientmatch field for ruleindex. All of the match strings are already in the clientmatch list |
1704064 |
Clientmatch host name too long |
1704065 |
Clientmatch domain name too long |
3277000 |
Upgrade all nodes to Data ONTAP 9.0.0 or above to use krb5p as a security flavor in export-policy rules |
3277083 |
User ID is not valid. Enter a value for User ID from 0 to 4294967295 |
href |
string |
_links
export_client
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
export_rule
anonymous_user |
string |
clients |
index |
integer |
protocols |
array[string] |
ro_rule |
array[string] |
rw_rule |
array[string] |
superuser |
array[string] |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
