Configure a data SVM as a proxy
POST /security/authentication/cluster/ad-proxy
Introduced In: 9.7
Configures a data SVM as a proxy for Active Directory based authentication for cluster user accounts.
Required properties
svm.name
orsvm.uuid
- Name and UUID of the SVM for a cluster user account.
Related ONTAP commands
security login domain-tunnel create
Name | Type | In | Required | Description |
return_records |
boolean |
query |
False |
Request Body
Name | Type | Description |
svm |
Example request
"svm": {
"name": "svm1",
Status: 201, Created
Status: Default, Error
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
cluster_ad_proxy
The SVM configured as proxy for Active Directory authentication of cluster accounts.
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
