Create a SAML service provider configuration
POST /security/authentication/cluster/saml-sp
Introduced In: 9.6
Creates a SAML service provider configuration. Note that "common_name" is mutually exclusive with "serial_number" and "ca" in POST. SAML will initially be disabled, requiring a patch to set "enabled" to "true", so that the user has time to complete the setup of the IdP.
Required properties
idp_uri
Optional properties
certificate -
enabled -
host
verify_metadata_server  |
boolean  |
query  |
False  |
Verify IdP metadata server identity.
return_timeout  |
integer  |
query  |
False  |
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
certificate  |
host  |
string  |
The SAML service provider host.  |
idp_uri  |
string  |
The identity provider (IdP) metadata location. Required for POST operations.  |
Example request
  "certificate": {
    "ca": "string",
    "common_name": "cluster1",
    "serial_number": "1506B24A94F566BA"
  "enabled": null,
  "host": "string",
  "idp_uri": "https://idp.example.com/FederationMetadata/2007-06/FederationMetadata.xml"
Status: 202, Accepted
job  |
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
12320789  |
Failed to download data file from specified URI.  |
12320794  |
The host parameter provided must be the cluster management interface's IP address. If the cluster management interface is not available, the node management interface's IP address must be used.  |
12320795  |
A valid cluster or node management interface IP address must be provided.  |
12320805  |
The certificate information provided does not match any installed certificates.  |
12320806  |
The certificate information entered does not match any installed certificates.  |
12320814  |
An invalid IDP URI has been entered.  |
12320815  |
An IDP URI must be an HTTPS or FTPS URI.  |
href  |
string  |
_links
certificate
ca  |
string  |
Server certificate issuing certificate authority (CA). This cannot be used with the server certificate common name.  |
common_name  |
string  |
Server certificate common name. This cannot be used with the certificate authority (CA) or serial_number.  |
serial_number  |
string  |
Server certificate serial number. This cannot be used with the server certificate common name.  |
security_saml_sp
certificate  |
host  |
string  |
idp_uri  |
string  |
job_link
uuid  |
string  |
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
